Odometer not working
was just wondering if anyones ever had this problem, i noticed my Odometer wasnt working when i was driving down the street, it was stuck at 0MPH the whole time! im taking it in on monday to have them check it out....just wanted to know if anyone else has had this problem and what caused it to malfunction
yeah yeah exactly my bad felluhs lol......its my dealership who confused me, one lady said speedometer, the other said odometer......eh you know.....ADD kicking in i guess, anyway anyone ever have this problem??? with the SPEEDOMETER, and do u know how long it will take to fix, im dropping it off at 8......hoping it will be done by 2:30 when im off work
Well depends on if the cluster went bad or if it is a HEC problem, and if they have the parts in stock.
Did you try the HEC speedo to see if that is registering anything ?
http://www.mustangworld.com/ourpics/News/99hec.htm
Once you enter the test mode, the first test is a gauge sweep test. That will show if the speedo is connected to the HEC as a starter.
Start the engine next I think is the step to get the motor running while in test mode, and then when you get to the selection of m that is the speed in kph rather then mph. If you drive the truck and get a reading here, is it most likely the cluster needs replacing, and should be a short job if they have it in stock.
If the HEC does not read a speed while driving at selection m, then you have another problem all together.
Good luck
Steve
Good luck
Steve
the odometer works fine, ive actually put on about 2100 miles in a month so thats fine, but my speedometer sticks until i hit 10mph then it jumps up to the right spot....im hoping they can get it done quickly since im a freak when it comes to having my truck at all times
When new
Mine had a problem where the speedo would go nuts for short periods, they ordered a new instrument cluster and it took about 3 hrs to install, no more problem, they also had to give me new keys as they apparently had to reset the chip somehow??
