SuperCrew
TSB Information for ALL vehicles
Old Jan 1, 2003 | 10:49 PM
Rockpick's Avatar
Moderator &
This may be very easily obtainable but, this is the first time I've ever come across something that provides so much data concerning TSBs on ANY vehicle out there...
I have access to TSB information on any vehicle on the market (including many 2003 models).
If you are interested in obtaining this information, simply drop me an email with the make, model, and year of the vehicle (trucks, cars, vans, etc) and I'll respond with the information. For example... after running my truck (a 2001 Ford Truck F 150 Super Crew 2WD V8-330 5.4L SOHC VIN L SFI), I obtained the following...
Safety Recalls
01S24 AUG 01 Recall - Defective Wiper Motor Switch/Gear Cover
01S21 JUL 01 Recall - Outboard Seats Belt May Not Fully Latch
01S10 MAR 01 Recall - Driver's Airbag Replacement
01S11 MAR 01 Recall - Front Brake Hose Replacement
00L11 FEB 00 Recall - Revised Child Tether Instructions
Emissions Recalls
01E16 DEC 01 Recall - Oxygen Sensor Inspection/Replacement
General Recalls
01B83 OCT 01 Campaign - Cooling System, Sales Literature Error
00L12 JAN 01 Campaign - Warranty Guide Supplement
Service Bulletins
02-12-1 JUN 02 A/C - White Flakes Coming From Vents
02-12-3 JUN 02 Engine - Lacks Power in High Temperatures
02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips
02-10-8 MAY 02 Fuel System - Whistling Noise
02-5-8 MAR 02 PCM - DTC's P1635 or P1639 Set/4X4 Lamp ON
02-3-5 FEB 02 Tailgate - Squeaking/Binding Condition
02-4-5 FEB 02 Battery - Charging Tips and Guidelines
02-4-1 FEB 02 Idler Arm - Replacement Specifications
02-2-3 FEB 02 Engine - Aluminum Block/Head Machining
02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures
02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications
02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment
01-25-5 DEC 01 Brakes - Reduced Power Assist in Freezing Temperatures
01-24-6 DEC 01 Engine - Oil System Priming Procedures
01-24-8 DEC 01 Seats (SIR) - Vibration or Shake at Idle
01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations
01-21-4 OCT 01 Bi-Fuel - Lock Off Solenoid/Tank Valve Coil Resistance
01-21-5 OCT 01 Engine - High Idle/Sticking Throttle
01-21-6 OCT 01 Hood Lamp Switch - Revised
01-20-5 OCT 01 Driveability - Vacuum Leak Detection
01-24-1 OCT 01 Clutch - Pedal Stays On Floor/Does Not Disengage
01-19-4 OCT 01 Hood Lamp Switch - Updated Replacement Part
01-18-1 SEP 01 Shift Interlock (BRAKE) - Inadvertent Disabling
01-15-7 AUG 01 A/T - Fluid Application Charts
01-15-6 AUG 01 Heater Core - Repeated Failure
01-13-5 JUL 01 A/T - 4R100 Delayed or No 2nd Gear Shift
01-13-7 JUL 01 A/T - 4R70W Clunk Noise on 2nd to 1st Gear Downshift
01-11-7 JUN 01 A/T - 4R70W Delayed Engagement/No Forward Gears
01-11-12 JUN 01 Tail Lamp - Moisture/Dirt Inside Lens
01-10-11 MAY 01 Bi Fuel System - Component Identification
01-10-1 MAY 01 Parameter Identification Data Input and Output
01-10-12 MAY 01 Wire Harness - Terminal Repair Kit
01-9-8 MAY 01 Door/Tailgate - Corrosion
01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis
01-9-1 MAY 01 PCM - Vibration at High Speeds/Trans Extension Housing
01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers
01-6-2 APR 01 PATS System - Diagnostic Service Tips
01-5-8 MAR 01 A/T - 4R70W Ticking Noise In 1ST Gear
01-4-7 MAR 01 Engine - Oil Recommendations/Applications
01-2-5 FEB 01 Seat Belts - Warning System Operation
00-23-10 NOV 00 A/T - In Line Fluid Filter Kit
00-22-2 OCT 00 Steering - Correct Placement of P/S Pump Bolt/Washer
00-16-1 AUG 00 A/T - ``Prior To Repair'' Tag Procedure Notice
As most all of you know, the TSB isn't a 'fix' for a problem on a vehicle but, it is a sure fire starting point to a specific problem. I'm not able to elaborate on any of the data that I've printed above but, if you walk into your stealership armed with this information, they may be able to better diagnose a problem that you may be having.
The Tranny thunk is one of the biggest problems going for our SCREWS... hence, it is listed. The TSB is 01-13-7.
Also, keep in mind that all of the recalls are listed however; you're particular vehicle MAY NOT BE LISTED OR INCLUDED IN THE RECALL. The best way to determine if you're in a recall situation is to call the Ford Customer Care number and you can find that on Ford's website.
Please feel free to email me questions and requests. I won't honor or fill any information requests (TSBs/Recalls/etc) posted on here as it will simply clutter the thread. I will answer simple questions (if, of course, I know the answers).
A quick link to my email can be found in my signature line.
RP
Old Jan 1, 2003 | 10:54 PM
kkirt1's Avatar
It would be nice to be able to see the full TSB text on the Clunk. Anyone have access to these?
Old Jan 1, 2003 | 10:57 PM
Harley#356's Avatar
Thanks RP
good think you didn't post my 85's chart up as your example, this thread would have a mile of scrolling down
Old Jan 1, 2003 | 10:58 PM
dcovell's Avatar
I found a link that has the TSB info but you need to be a memeber (paid) to access the full text of the TSB.
http://www.alldata.com/TSB/
Old Jan 1, 2003 | 10:59 PM
Rockpick's Avatar
Moderator &
NO PROBLEMO... Glad to help... I firmly believe that this is why we have this forum... it's here to share data...
If you want this data for your truck, car, van, bicycle; simply email me using the email link above.
The only information that I will need, initially, is the Make, Model, and Year of the vehicle. I may email you with a request for additional information if there is something specific (like many of the fords have) like the vin letter code.
RP
Old Jan 2, 2003 | 10:50 AM
welfare wagon's Avatar
Rockpick can you find anything on a 2003 F-150 Screw XLT 5.4 V-8 2WD. I am having problems with my keyless entry working no more then 10 -15 feet from vehicle or not at all
Old Jan 2, 2003 | 11:43 AM
titank's Avatar
Hi Guys,
I have access to AllData and checked that tsb. That particular tsb is not what you guys have mentioned. This is regards to a 2 to 1 downshift. That notice is from 7/09/01.
Here is a partial copy of it-the full tsb is way to long.
Article No.
01-13-7
07/09/01
^ NOISE - "CLUNK" NOISE HEARD ON 2-1
DOWNSHIFT VEHICLES EQUIPPED WITH 4R70W
AUTOMATIC TRANSMISSION
^ TRANSMISSION - 4R70W - "CLUNK" NOISE HEARD
FROM TRANSMISSION ON 2-1 DOWNSHIFT
FORD:
1999-2001 CROWN VICTORIA, MUSTANG
1999 F-250 LD
1999-2001 E SERIES, EXPEDITION, EXPLORER, F-150
LINCOLN:
1999-2001 TOWN CAR
MERCURY:
1999-2001 GRAND MARQUIS, MOUNTAINEER
ISSUE
Some vehicles equipped with a 4R70W automatic transmission may exhibit a "clunk" noise during the 2-1 downshift event. The "clunk" noise will be consistent in nature, and will occur during most 2-1 downshifts. This may be caused by a Planet Support Spring that is out of position.
ACTION
Check for the correct installation of the Planet Support Spring. If the spring is not installed correctly, the Planetary Gear Support will make contact with the transmission case during the 2-1 downshift, causing the "clunk" noise. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
NOTE THE "CLUNK" NOISE DESCRIBED IN THIS ARTICLE SHOULD NOT BE CONFUSED WITH HARSH/ROUGH 2-1 DOWNSHIFT CONDITION. IF A HARSH/ROUGH 2-1 SHIFT CONDITION IS PRESENT, FOLLOW NORMAL WORKSHOP MANUAL DIAGNOSTIC PROCEDURES
I have checked for other tsb's related to a thunking noise and have found none.
Old Jan 2, 2003 | 12:38 PM
dcovell's Avatar
That sounds like it to me. I think I will make an appointment to have this fixed before my 36000 warrently runs out.
Im just over 30k now and am due for a transmission check-up. But this sounds like it could be expensive to have done out of warrenty.
I know they can't give me a bad time about the computer chip, but I should take it out anyways to avoid any moron that will come up with any excuse not to do the work.
Old Jan 2, 2003 | 01:05 PM
racer47's Avatar
Unhappy Me Too
Im having the same problem as Welfare Wagon with my keyless entry. Is this normal for everyone ? Its almost useless!!
Mike
Old Jan 2, 2003 | 04:34 PM
coopersunc's Avatar
Take it to the dealer. Probably a weak battery in the sending unit. My '03 remote works from 20-30 yards!
Old Jan 2, 2003 | 05:34 PM
onebohemian's Avatar
You can get a list of the TSB and recalls for any particular vehicle at www.nhtsa.com (the national highway and transportation safety agency). For a very few of the TSBs, they include a pdf of the entire TSB, but it's very rare. Still doesn't hurt though to check this once in a while. When I ran the 2003 F-150 just now, the only one that came up was for moaning in the rear brakes at slow speed stops. Haven't heard of anyone complaining of that yet on this site.
My 2 cents,
Mark
Minneapolis, MN
Old Jan 2, 2003 | 06:56 PM
dcovell's Avatar
My transmitter worked from almost 30 yards away when it was new and the range has definatly gone down over time. I have had it now for over a year and 4 months. I think I will put a new battery in the remote soon. Also if I am in an area with lots of TV/radio transmitters around the remote sometimes won't work at all even standing right next to the truck.
Old Jan 7, 2003 | 12:03 AM
jryager's Avatar
Hey, funny thing, one of the salesmen at the dealership who used to work at a large dealership told me this one. To get your keyless entry to work from further away, hold the keyless entry fob under your chin (touching your chin). It really does increase the distance. I have seen mine work from 75 yards away.... not sure what makes it work better......
Old Jan 7, 2003 | 12:41 AM
dcovell's Avatar
Your making yourself an antenna. Sounds like an intresting idea, I will have to try it...
I have accidently set my panic alarm off from inside a building with my truck in the underground parking.
