Crash-2)quick ??s
Old Apr 12, 2002 | 07:55 PM
max mitchell's Avatar
Question Crash-2)quick ??s
Will the ATI Procharger pulley fit on a ASP harmonic balancer/pulley? Will the ATI intercooler tubes that go through the shroud clear aftermarket dual electric cooling fans? I read about your ATI upgrades---On the 5.4 will these include injectors, MAF, and fuel management? Is this a FMU removal, a chip, and an in-tank fuel pump upgrade? Any help would be greatly appreciated.
Old Apr 13, 2002 | 06:28 PM
Crash-
Thanks alot !!
Old Apr 13, 2002 | 06:55 PM
ganiman's Avatar
im using the flexalite #250 dual fans w/ my ati..The piping from the ati tubes must b cut and modded..troublesome,but possible
Frank
Old Apr 15, 2002 | 01:50 PM
Blown2run's Avatar
max mitchell
No underdrive pulleys with the ProCharger. You need to put your stock pulley(s) back.
Old Apr 15, 2002 | 02:02 PM
ganiman's Avatar
Sure,I'll borrow my friends digicam and figure out how to post a pic here.
Frank
Old Apr 15, 2002 | 02:07 PM
Thumbs up ganiman, Blown2run-
Thanx for the additional info.
Old Apr 18, 2002 | 11:33 AM
Question Crash-
I'm still curious !! On a 5.4 ATI setup, are the "custom Superchip, injectors, MAF, and these other mods" available yet? If not, what's the projected date and will these be described on your website? So, you remove the FMU and tune with the chip, correct? If so, what's the fuel pump upgrade (still inline or in tank)? Can you describe the sizes and companies that produce these parts? Can the Superchip reprogramming for this be done to the standard chip that I already have?
Old Apr 18, 2002 | 04:29 PM
Crash-
Thanks for the information.
