CAI issue, after replacing the Roush airbox?
Vid of my M112 on the Dyno.
http://vid127.photobucket.com/albums...0/IMG_0278.mp4
Is your set up louder than this?
The late Roush 108mm Airbox set up is far superior to any other kit. Panel filters flow better than cones.
The only reason Iam not using it on the Whipple is the transition between 95 and 108mm might give us idle issues.
I'll tell ya, I'll be more than happy to put the stock air box back on if someone like K&N would make an aftermarket filter for it.
K&N is 10miles away from me. I contacted them to see if they would be interested in making a filter for the Roush air box. They replied that there isn't enough of requests to make it. To which I replied, "But there is for a 72 MG Midget?"
I'm not sure if this was directed to me but I gotta say my set up is not much louder than the stock Roush air box though I don't really know how it would sound with the hood up doing dyno pulls.
I posted the vid as my head unit is a snake bite conversion with straight cut double drive gears, Max port and scilencer holes filled. Stock Airbox.
The point was : If you want it to scream like that then send it off to Stiggy.
An alternative filter would be nice. Or just a cheaper OEM.
I just have supercharger and plenum ported and silencer holes filled.
I see there are options for snake bite and venom cooler
The venom cooler was $350.
The head unit is loud! It's even loud during partial boost. The fact I run stock exhaust eliminates other sounds that could drowned it out.
I'm getting my engine built to handle up to 900HP if everything goes as planned in the next few weeks.
I wonder how much boost can we push on that little M112, and which upgrades should I do so it can support it, ie. venom cooler, snake bite.. any suggestion is appreciated, I already got twinscrew pov on this
Anyhow, the M112 can go upto 17'000rpm. Anymore then your gonna need light weight rotors bla bla.
Buy some coggs and be happy with whatever HP it dishes out.
Haha. I was as supportive as can be. I encouraged him to talk to Steigmeier about the snake bite and venom kit. Upgrade the heat exchanger and that do to design limits the Eaton experiences demising returns past 14psi. The cooling mods will help with this but your still limited do to the intake neck between the throttle body and blower. Not gonna flow much air through that 75mm neck.
Very expensive but very awesome. https://www.google.com/search?q=cog+...x%3B1024%3B621
I have a Roush CAI Supercharger "Tube" only...no filter no brackets, just the Tube. I also have an Extra Supercharger with teh Boost Bypass mounted on it. All is in perfect shape. Willing to sell it. This from the Roush 2004-2008 Intercooled Kit. I had an extra laying around just in case.
jeffbanghart@***.net
