02 Harley truck has the hiccups when it goes into boost
Old May 17, 2014 | 04:25 PM
ratel1975's Avatar
put it in the shop today they said it was the transmission torque converter is shattering they are taking the transmission out to see how bad it is internally made me complete rebuild for $3000 on a truck with 58,000 miles on it....when I accelerate hard the supercharger goes in and out of boost if you get on it soft it's not bad at all truck runs and idles fine only has problem when the supercharger kicks in. I brought the truck 2 months ago truck is bone stock has 58,000 miles on itwhen it happens that truck jerks hard and you can hear the supercharger whine truck is not throwing any codes everything on the truck is original.
Old May 17, 2014 | 05:54 PM
jokerzL's Avatar
Mods list buddy
Belt slip may be an issue
Boost actuator could be failing
Spark blow out
Plugs are gapped to big
Bad idlers
Spring tensioner
Tune can cause "hiccups" when going wot. Causing a stall effect
Need a list of mods tho to answer more questions thoroughly
Questions I have to ask
Pullied? If so how?
Last time you checked your plugs?
How old is the belt you have on?
Idlers ever been replaced?
Have you ever had the supercHarger off the truck?
any codes?
Old May 17, 2014 | 07:26 PM
widj's Avatar
could also be an electrical problem and/or fuel pump is getting old and not supplying enough fuel to the engine
Old May 19, 2014 | 08:29 AM
jokerzL's Avatar
Check all these things
Lightning newcomer
Tune
Maf
Exhaust
Cai
Valve body
Port
6 lb
Plug change to tr6s to .034
Intercooler clean
Intercooler line upgrade
Check actuator
Check intercooler pump
Change fuel filter
Check alternator and battery voltage
Check grounds
Check fuel pumps
Old May 20, 2014 | 01:09 PM
ratel1975's Avatar
02 harley truck hiccups
put it in the shop today said it was the torque converter shattering
