supercharging my f-150 5.4
For tuners you can go with Finishline automotive & performance on 64th and Federal. They almost exclusively tune and build out modular motors. They tuned my truck and many other lightning's around here. I have mixed feelings about them sometimes, but they seem to know their stuff. I've also heard JJ is good too.
For Gaskets I'd go OEM. Id stick with the N/A harness and use the Lightning Vac harness. From the looks you will need injectors. Get the OEM greentops - they can be picked up for cheap on lightningrodder.com. You will probably want to pulley up, im not sure that the stock pulley will fit on the N/A timing cover.
For fuel pump id get a single walbro 255 for ease of installation and not having to hack up the fuel hat etc...
Id just buy a new IAT2 Sensor from Omera ford. I think it was around 15$. The current one you have will be of no use. The IAT will have to be relocated into the manifold.
Otherwise if you get a heat exchanger, gaskets, i/c pump, EGR tube, and the intake assembly it looks like your mostly set. Also those throttle cables are gonna be a bitch to find.
You got my email if you need the complete list. Good luck!
One question since you know your pullies - I'm using an ASP 8.40" #4 pulley on my 02 N/A engine. It seems to be balanced most of the time, but i suspect it's not 100% spot on. I'm using mikes special ring adapter as well.
Do you know if this combination is technically balanced properly? It's really hard to find this information.
Dave
I have no idea on what year it's for. I'm assuming a 99-00 since it came bundled with a more or less complete 99-00 swap setup. (i bought it used). Is there a way to check on the ASP pullies that you know of? The pictures of the 99-00 ASP and 01+ ASP's are 100% identical.
It seems to be rotating properly 95% of the time. But when i took it hunting, the trails did a number on the pulley balance. It's corrected for now, but im wondering if im missing something. It seems like the bumps shouldn't "knock it out of balance".
