90MM Ford Motorsport Throttle Body
So I got lucky and found some 4" silicone hose today. Picked it up for $20 bucks at a boat yard. This particular hose is normally $150 per foot. Got it installed. Now I want to pull some of throttle motor wire out of the harness to route it behind the throttle body for a cleaner appearance. Maybe paint the chrome elbow black? Whatcha think?
A little yes. Throttle response is improved. It only takes about 3/8 of pedal push to break lose the rear tires. Gotta get use to that. Before it was half way. The real difference if any will show itself at the track. After all, the restriction I measured before was above 11psi and up. And mostly 4000 rpms and up. Hard to feel 20hp in that area. You want to feel it so you do. This is when I miss the ex lol. When I would modify our SHO that she drove daily I would do so and not tell her. When she came home the next day grinning from ear to ear saying what did you do? I knew for sure what the worth while mods were.
Crash I am not thrilled with the blue. I wanted black silicone or the dark blue. This stuff is light blue and I'm not happy about that. However it's an 1/4 thick so it will take a lot of idle for heat sink to take place. For $20 i couldn't beat it. I will run across some black eventually. Just not paying $75-150 per foot.
