Jabsco Pump Install & Test
Happy to report a 10 degree drop in my ACT's at WOT! I was able to repeat my test this morning as outdoor temp was 71. My peak ACT was 126F verses my previous run at 136F under the same conditions.
At the beginning of the run my ACT was 98-100F. Really happy with the results. 12psi heats the air about 120f so my set up is removing 94 degrees of that. $143 to drop temps an additional 10 degrees is not bad.
I still feel an increase in reservoir size and/or a larger HE would bring temps down even more. I will fab up a reservoir first as I already have some resin.
Will do Ken. Just secured it this past week. I was able to get it to sit a little closer to flush. Gonna test this afternoon to see if it helps underhood temps. Going to repeat a test I did when I installed my custom intake that revealed underhood temps of 140f when sitting idle for 13 mins.
I'm not sure if this has been tried, but what about spraying water on the intercooler? I do refrigeration for a living and a lot of heat can be removed by adding water to a coil. This may be common and I just don't know it. Either way I think it would be an easy way to get a little more cooling.
