Those with over 10psi on roushcarger...
Old May 14, 2013 | 05:00 AM
scobar's Avatar
What other support mods were required?
Maf?
Injectors?
Pump?
Curious as I am looking for more go
Old May 15, 2013 | 07:25 PM
scobar's Avatar
damn, no love
Old May 15, 2013 | 08:21 PM
Ross-FX4's Avatar
Mine peaked @11psi at a boost friendly altitude.
Stock fuel pump / lines.
Roush 38# squirters. Roush MAF is 108mm so no worries there.
Old May 15, 2013 | 08:57 PM
twinskrewd's Avatar
38's Ross??? I thought the Roush kit came with 42's (green Bosch) injectors.
Old May 15, 2013 | 09:43 PM
IR0NS1N's Avatar
I thought it came with 39lb injectors
Old May 16, 2013 | 08:16 AM
scobar's Avatar
The PN in the kit comes back to these:
http://www.roushyatesparts.com/parts...0002-11-aa.htm
Which appear to be advertised as 38# units.
So I guess, if I want to push it, what am I looking for on the fuel system support?
I have a 255lph pump coming, will this be enough?
I currently have 38# injectors, will this be enough?
I currently have the stock maf, will this be enough?
Currently running a 4# lower and stock roushcharger upper pulley. I've read and heard that I could go to a 6# lower without issue. I have a 8# at the house. Obviously I will require retune.
Would it be more advantageous for me to send the blower and lower manifold out for porting instead?
Old May 16, 2013 | 05:08 PM
scobar's Avatar
AIT is in intake mani. On boost gauge I see 9psi. Currently headers, no cats, and single 3" exhaust.
Old May 16, 2013 | 06:58 PM
Ross-FX4's Avatar
Yeah I have some Troyer 48#'s but went with the Supplied 38's.
100% recommend getting the blower ported, scilencer holes filled and work on the plenum hat.
The tuner accounted the steady boost to the Stieggy port.
Old May 16, 2013 | 08:05 PM
scobar's Avatar
The stieggy porting, is that the manifold, hat, and blower that he quotes out at $750? Is tuning required if I get this work done?
Old May 19, 2013 | 09:44 PM
scobar's Avatar
Bump.
Old May 19, 2013 | 09:52 PM
IR0NS1N's Avatar
Yes retune required.
Old May 19, 2013 | 09:59 PM
Ross-FX4's Avatar
Don't know. I never ran it stock.
I lucked out and bought the set up already @ stage V 'Snake-Bite' conversion. So I had it rolled as is.
I assume the work is just the blower case and a front end rebuild.
IDE send it in for a port, silencer holes filled. Maybe have the plenum hat
Hump removed and the TB ported.
Old May 21, 2013 | 08:09 PM
scobar's Avatar
Any DIY options on porting? I have access to plenty of air. Just curious.
At what point does one need more fuel pump or injectors? I have a 255lph pump coming.
Old May 24, 2013 | 07:36 PM
scobar's Avatar
Ok, I got a gt500 heat exchanger and steel on order to mount it out front.
Should I even bother with keeping the roush behind the ac condenser and run both, or stick with the 1 out front?
Will be mounted something like this when done:
Old May 24, 2013 | 07:40 PM
twinskrewd's Avatar
Run both. Put the Roush in front of the ac condensor and I would mount the GT500 behind the bumper opening.
