help with A/F data
Old Apr 27, 2013 | 02:01 PM
kens fx4's Avatar
help with A/F data
ok.. so i have a x3 and a aem wideband gage
i've got it all wired up and can see it logging on the livewire program
but when i run the truck the gage shows me one thing
then i look at the data i log and its another thing
example gage shows 12.6 and data shows 11.2
big diffrance.. why? wich one is correct..
thanks for any info
Ken
Old Apr 27, 2013 | 06:26 PM
twinskrewd's Avatar
Hope it's the 11.2 if you are at WOT. 12.6 will snap a rod. Is your gauge calibrated properly? Also is your gauges O2 sensor located before or after the cats?
A quick example of gauge calibration from my experince. Troyer set my tune to command 14.1 as stoich to account for a maximum of 10% ethonal content. My wideband read 14.7 as this was its factory setting. Once I calibrated it for 14.1 it read properly at idle and reads 11.2 at WOT as commanded in the tune.
Old Apr 28, 2013 | 01:38 PM
kens fx4's Avatar
first.. the os is before the cat.
you can NOT calibrate the aem gage...(talked to them already on that)
and the gage reads 12.6 WOT
but the data log info reads 11.2
so me and the tunner are going round and round..
so i chould make the data log read the same as the gage
thanks
Old Apr 29, 2013 | 08:41 PM
scobar's Avatar
How does one calibrate?
Old Apr 30, 2013 | 12:19 AM
twinskrewd's Avatar
The Autometer gauge has the instructions with it. If you have misplaced them like I did heres a link http://www.autometer.com/download_instruction/1143A.pdf
Old May 4, 2013 | 05:17 PM
are you using the correct gauge equasion in the settings before you datalog.....
when you select the gauge in the laptop screwdriver make sure you click apply....
