Stock thermostat?
Hey twinskrewd, got a question just for my own gee-whiz!
Is it normal for blown guys run an oil temp gauge of some sort? How do you come across these numbers?
I've been running an oil temp gauge on two trucks for about a combined 200,000 miles. On a N/A 5.4, oil temps hover right around 100* above outside air temp under normal driving conditions. There's a few variables, but it takes some serious towing or agressive driving to drive them much above that point; it's very consistent.
I do imagine forced induction adds a bit of heat to the motor, especially when running it, but that's substantially hotter and it would take a sustained energy to drive the oil temps up that much.
Like I said, 100% complete curiosity on my part, nothing more.
Thanks dude.Yea, with constant (oil) temps in that 230-280 range, I guess you guys could use an oil cooler. I probably talk at least one guy a year out of putting an oil cooler on a normal truck...completely not needed. In fact, IMO, I wish there was a way to make the oil run warmer. When outside air temps get down in the low 40's, I'm already completely closing off the front of my radiator just to get my oil and tranny temps up to something remotely resembling warm! Anyways, thanks for the info...back to your regularly schedule program
www.reischeperformance.com great thermostat. I believe these are ones Troyer carries too. Got mine from him for $40.
Tim
A little more info on why to run a cooler stat in a performance application can be found here. This is a great read and includes a section about thermostats about halfway down.(qouted below) Every 8-10 degree of water temp drop is the same as adding one more octane number to the fuel. Warding off detonation indeed! http://www.popularhotrodding.com/tec...ech/index.html
"Running High Ratios and Living
The factor that ultimately limits the amount of CR that can be used is detonation. The key to being able to utilize high compression ratios and have the engine survive is to understand what factors can accelerate its early onset. Here the temperature of the intake charge is probably the number one issue to address. In practice we find that for an engine on the edge of detonation, every 8-10 degrees F reduction in intake temperature is equivalent to adding one more octane number to the fuel.
Most stock engines of the post '70s emission era are on the edge of detonation and run with water temperatures in the 200-210 range. While this may be good for lower emissions, it is not good for power or staving off detonation. For a high-performance street machine running service station fuel, water temperatures of 170-180 deliver a couple percent more power and the ability to use about a quarter of a ratio higher for every 10 degrees reduction in water temperature. Your first move toward utilizing higher CRs then is to use a 170-180 degree thermostat."
Twinskrewed, I have a question for you. I just sent my tuner back to Troyer yesterday for him to make my performance tune. Do you think it would be a good idea for me to ask him if he can account for a 170* thermostat and have him send me one with the tune? Also while I am on the subject, do you think there is anything else worth adding without spending a crap load of money that might help performance wise?
What brand supercharger belt would you recomend with the 2.80 pulley?
Sorry for jumping subjects!
I would suggest calling Mike and discuss the T-stat change with him since you live up in the frozen tundra
. Some of the GT-500 guys that live up north run the 170 stat in the warmer months with a kick *** tune and switch to a winter tune and 190 stat (stock) during the cold months. This is what I would do but discuss it with him. And if you elect to do it have him adjust the tunes and send you a 170 stat and a belt. He keeps all of it in stock and maybe he will make you a deal for the 3 purchases. The Gates belt is my favorite and it never hurts to have a spare. I keep my extra under the seat with the jack. Tell Mike Jason Barker sent you
