All I want for Christmas is a WHIPPLE!
Old Jan 1, 2012 | 02:29 PM
  #31
kozz's Avatar
Tecmotion in Calgary
Old Jan 9, 2012 | 12:18 AM
  #32
tgpatrsn's Avatar
How is the truck running?
Old Jan 11, 2012 | 07:47 PM
  #33
Brain_Mach1's Avatar
I noticed it is labeled Ford Racing Whipple. I thought all those were bought up in 2010, like when I bought mine.
Old Jan 12, 2012 | 11:02 AM
  #34
05supercrew's Avatar
Any updates looks great.
Old Jan 12, 2012 | 08:29 PM
  #35
kozz's Avatar
Dyno done on Tuesday. Everything is great, runs smooth and is a real kick to drive! Got a fantastic AFR after a few different tunes, ended up writing two. One for just truck and one for towing.
Best numbers were in the range of 335hp and 330 torque. Was on a mustang dyno that apparently is stingy on the numbers. I never really knew that different dynos could spit out such different numbers.
One thing we did run into, my stock fuel system is maxxed out. If I want to go with more boost then a fuel pump upgrade is required. We'll wait and see....
Old Jan 12, 2012 | 08:32 PM
  #36
javier garcia's Avatar
With how much boost was this ?
Old Jan 12, 2012 | 08:45 PM
  #37
kozz's Avatar
6 lbs
Old Jan 12, 2012 | 08:50 PM
  #38
onestout's Avatar
Did you upgrade your injectors to the 39lb. ones?
Old Jan 12, 2012 | 08:53 PM
  #39
kozz's Avatar
I went 47# just in case the future lead to upgrades
Any suggestions on fuel pumps? Plug and play solution?
Old Jan 12, 2012 | 09:42 PM
  #40
onestout's Avatar
I'd be interested in which fuel pump to put in as well, might as well do it while I have things apart.
Old Jan 12, 2012 | 09:56 PM
  #41
twinskrewd's Avatar
I don't mean to be negative but something is wrong here. And kozz please don't take this as me knocking your truck. I hope I can help. The stock Whipple setup makes 8psi which will typically drop to 7.1 or 7.2 psi with headers and true duals. The next thing is the power. 335hp and 330tq???? This isn't right even at 6psi which is what some gauges will read. The stock kit and tune always put down 390-400rwhp and around 440rwtq. Even when truckin magazine did the install they got these numbers. http://www.truckinweb.com/tech/engin...0/viewall.html
Next is your torque being lower than the hp. Something is way off here!!! Stock or supercharged the torque is always 40 or more higher. This has to do with cam profile. Trucks need more torque. You see hp higher than torque in cars. And lastly the stock fuel pump will support 420rwhp and 10psi with either 39, 42, or 47lb injectors. And thats on a truck with 35's. Any chance you can post your dyno sheet? You have no doubt spent a lot of money and you should be getting a lot more.
Old Jan 12, 2012 | 10:23 PM
  #42
coobies5's Avatar
mustang dyno is why the numbers are low
Old Jan 13, 2012 | 08:58 AM
  #43
twinskrewd's Avatar
It's true Mustang dynos read lower, this typically in the 8-12% range. This would still only put the truck in the 360-375 range. A good bit weaker than what should be expected of the canned tune. And still it doesn't explain the lower tq.
Old Jan 13, 2012 | 11:22 AM
  #44
kozz's Avatar
Now I'm worried.....here's the sheet. BLUE line tq, RED hp, Lt BLUE boost, Black AFR
Scale for boost and AFR aren't on the page. Boost is between 5 and 7 psi, AFR between 11 and 12
Not a canned tune. I never got the handheld from Whipple. They wanted me to send the ECM in.... I didn't. Should I have got the tuner?
Old Jan 13, 2012 | 11:47 AM
  #45
A friend also just installed his whipple, and he aswell was seeing 6psi. With a dyno tune he only managed to get 365rwhp and 390 rwtq I also thought those numbers were low. But when we went for a ride the truck felt a lot stronger than the numbers it put down on the dyno.
