Killed another 4R70W behind my 5.4 Lightning conversion - Suggestions
Old Aug 18, 2010 | 10:34 AM
KTrostel's Avatar
It appears that I just lost another 4R70W trans, this time a Monster Box unit. What are you guys running that can take the abuse (and I drive it like I OWN IT - ie many highway miles, no 1/4 mile, etc...) of a 5.4L with the L swap?
I've heard of others swapping in the 4R75. The truck is a 2001 supercrew 4x4, is this even an option for that year?
Old Aug 18, 2010 | 11:21 AM
JimmysotherFORD's Avatar
talk to this guy http://www.bcatransmissions.com/album1_011.htm
many people here are using 4r70/4r75s built by him and he also has tons of rep from mustang people also. talk to him tell him what you want (make sure you give him all the info about your truck the first time) and he'll make it for you.
Old Aug 18, 2010 | 12:31 PM
Klitch's Avatar
I'm using one built by Darrin Burch (screen name here too).
see sig for contact info.
Old Aug 18, 2010 | 02:46 PM
Veteran: Army
x2 on a 4r75 conversion
because a 4r100 is a PITA and not cheap
Old Aug 18, 2010 | 10:38 PM
Faster150's Avatar
also weighs 150lbs more and requires a custom drive shaft no to mention 1st and 2nd gear suck!
Old Aug 18, 2010 | 10:56 PM
Contact Darrin Birch of BCA transmissions.
He's one of the best tranny experts+builders.
Old Aug 18, 2010 | 11:11 PM
nonwoven29's Avatar
What about a 4r100 swap? My stock one took 14lbs of boost for a short while like 10K miles before letting go and MY FAVORITE GEAR WAS 3ED TO SECOND I had mine built race ready for only 2700 out the door with tax and all. I know for a fact that the punisher on here and Lrodder.com does killer work I had his VB installed on this fresh rebuild and it can be neck snapping even in a 6K lbs suv with a 3k stall cant wait for the cash for an YSi or J trim
Old Aug 19, 2010 | 12:21 AM
05SilvrFX4's Avatar
If you are near MI, get a hold of Pauls High Performance. www.paulshp.com
They did my fathers lightning motor swap and built his 4R70W. He has 35" tires and 4.56 gearing, the truck is used for towing and as an offroad toy, the trans was built stout.
Old Aug 19, 2010 | 07:04 AM
CobraKit's Avatar
I installed blower at 90,000 miles and now have 155,000 miles with 4r70w. Only thing I did was add shift kit. Boost has always been over 10lbs, currently pullied to 16lbs. Daily driver with occasional towing. Must be lucky, knock on wood!!!!!
Old Aug 19, 2010 | 09:39 AM
KTrostel's Avatar
You'd better keep knocking. Your story is almost exactly like mine installed blower at 107K, 10 PSIG, shift kit from Troyer, Original 4R70W died at 130K. Now the monster box at 185K. I will keep your trans in my prayers
Old Aug 19, 2010 | 09:42 AM
KTrostel's Avatar
Problem with the 4R100 is the fact that my truck is a 4x4. To swap in the 4R100 is a MAJOR PITA! Lots of custom work plus need an aftermarket controller. And in emission controlled areas (like St Louis) any change to the original PCM will cause your vehicle to fail (VIN's don't agree = failed emissions). Why? Cause the government dweebs can't understand that sort of change....
Old Aug 19, 2010 | 09:43 AM
CobraKit's Avatar
I knock on wood everyday And I still have the orginal battery as well. Must have been a good year!
Old Aug 19, 2010 | 01:31 PM
Klitch's Avatar
IIRC, even between 01 and 03 model years there was better quality parts used yet again.
Old Aug 20, 2010 | 06:45 AM
CobraKit's Avatar
Just remember to always disengage OD before slamming the throttle. This will help the tranny live a lot longer.
Old Aug 23, 2010 | 09:36 AM
KTrostel's Avatar
Thanks for the tip. I only heard that recently.
