Adapter plates?
there are several eatons the M90, M112 and M122 are the most commonly used on Ford vehicles
there is a couple kits that allow the use of the cobra M112 on the 4.2 V-6 motors, there are a few kits that use the M90 on the 4.0 V-6 motors...
what I recomend you do, is sit down, make a plan for your truck that will work with how you use it and how you plan to use it...
then once you have a list of the large pieces, we can help you with the small pieces that make it all possible
and regarding how much boost I'm pushing on my green truck, I know what I'm risking each and every time I see the needle on the boost guage go past zero
It will be used for nothing more than driving around/playing around. No towing or anything like that. It will be a beach truck/street queen.Call me whatever, but I wanna make my 4.6 have some decent power in the lower rpms. I know thats completely opposite of what its made to do, and just about everyone will say.. get a 5.4. If I could get a 5.4 for a decent price then I would just re-build it anyways so I dont mind some mileage being on it. I am having trouble finding a 5.4 separate from a whole truck
.I am down for piecing together a S/C set-up. Maybe if I find a blower for a decent price then I will pick it up and ask you guys what all I need to make it work. Maybe if I just buy it in pieces I will be less likely to notice that I am still spending 3-4 grand. Spending that much at once for something is nuts to me. :o
If ya were,
there is plenty out there!
http://shop.ebay.com/i.html?_nkw=for...acat=0&bkBtn=1
Phil
I have yet to hear of anyone with an M90 on a truck being totally happy with it. By the time you spin an M90 fast enough to get some decent boost out it, it makes a ton of heat. Trying to make the larger one fit is a tough job and expensive project, and still a lot of heat to deal with.
I would suggest a used Procharger or Vortech. They are out there at fair prices, and the used parts are available everywhere.
Here's one experience: https://www.f150online.com/forums/su...dyne-long.html
this is what I hoping he'd search and find
http://shop.torktech.com/99-04gtnon-...argerkits.aspx
it's the termi cobra M112 on a 2 valve 4.6
plus it'll be cheaper and he can use a wastegate for more low end
Your not trying to find a 5.4
If ya were,
Phil
If ya were,
Phil
Guess knowing where to look helps.
If I were to go with the tork tech kit then I would need to get PI heads as well wouldn't I? Would it be safe running a non-built block with that much compression and then slapping a supercharger on it?
On those tork tech kits.. do you buy one kit or the other being intercooled vs. not and then click each other option as "upgrades"?
I am looking for something easy to pick up parts for pretty much. This is not something I am looking to slap on tomorrow. I can "nickel and dime" parts no problems. I have always heard good things about Procharger, and wouldnt mind owning one at all. Is there a certain kit I need to buy or? You guys say the parts are pretty easy to come by so I think if I buy a decent chunk of what I need now then I can just start tying up the loose ends soon.
