Dyno Run results
Old Sep 24, 2009 | 01:27 PM
batn68's Avatar
Dyno Run results
o.k. finally got on the dyno after exhaust work (headers and such) and upgrading the lower crank pulley to what appears to be around 2-3 pounds more boost, around a 6% overdrive from my calculations, darn belt looks to be still slipping. The first run is stock (came with kit) air intake assembly, second run is changing out the intake to an open air setup I fabbed out of a spectre CAI for our truck, A/F on the second run was a bit lean on that, 3rd run (marked 4th) is the fabbed intake with fuel bumped to 6% at WOT and we see HP/TQ dropped a bit. Anyone know why it would do that?
Old Sep 24, 2009 | 02:53 PM
batn68's Avatar
here is one of the dyno pulls, it is a cruddy camera that can record for a few minutes, so its not all that great, exhaust does not pulsate like that in person, it's the camera microphone cutting out the sound. Watch the guys sleeve flap in the exhaust towards the end, most of it got him in the face.
http://www.youtube.com/watch?v=gCgXa-UjUe4
Old Sep 24, 2009 | 04:56 PM
FX4 Matt's Avatar
Registered User
them are good numbers for the magnacharger.
Old Sep 24, 2009 | 05:01 PM
weazel's Avatar
Registered User
the magnacharger is capable of good power, it is just stock the kit makes a girly 5 psi...
Batn68, If the third run is the way the truck is running now, 11.0 is on the rich side, but a very safe a/f, if you can take a tiny bit up fuel out, to make it 11.4-11.5 you will be good! Plus you prolly gain a lil more to the wheels.
Old Sep 24, 2009 | 05:58 PM
batn68's Avatar
It was set at 6% for that third run and this is what it is currently running, the next step down on the SCT would be 4%, do you think that this would be good to go? I also noted that the 6% makes it feel rather sluggish when I mashed the pedal and went into boost, at two percent when I was adjusting the WOT fuel increases before my dyno and running on my ho-made modified intake it felt good, but was lean most likely.
Old Sep 24, 2009 | 06:13 PM
bluebeast06's Avatar
bad news i took the blower back down to 8lbs, running out of fuel on the top end, mr troyer wants me to buy his fancy fuel system i would rather lose a couple ponys than buy a new motor
Old Sep 24, 2009 | 06:34 PM
weazel's Avatar
Registered User
How are you losing fuel up too,
Old Sep 24, 2009 | 06:35 PM
weazel's Avatar
Registered User
4% may be right in the middle, not lean but not rich..
Old Sep 24, 2009 | 07:29 PM
i dont know how but i belive it has something to do with being tuned for ethanol, where it take more fuel to burn, truck still runs but im on the point where i dont want to blow it up if i can help it.
Old Sep 25, 2009 | 12:02 AM
weazel's Avatar
Registered User
Wonder if you will make more if you can get it to boost 10 psi and a 11.5ish all the way...
Old Sep 25, 2009 | 08:12 AM
150xlt's Avatar
Nice numbers Are the magnacharger's intercooled?
Old Sep 25, 2009 | 10:59 AM
batn68's Avatar
yes they are intercooled.
Old Sep 25, 2009 | 03:06 PM
batn68's Avatar
The tuner noted my Stiege sticker on the magna and asked if I just bought the sticker and put it on there? I said yes but that was the most expensive sticker I have ever purchased.
Old Sep 25, 2009 | 06:44 PM
GerRod's Avatar
Nice numbers Batn. Did your tuner data log while it was on the dyno? If so, what was your IAT?
Old Sep 25, 2009 | 06:47 PM
batn68's Avatar
No data logging, this was just three pulls on the dyno to see what I was making, I had some previous mods done and wanted to know what my A/F and HP were.
