Dyno Run results
Was run 03 done with a substantial cool down period? The last run was rich, the 1st perfect with the middle being alright (more hp because of leaner fuel). Your tip in is pretty lean though, would like to see that richened up.
The third run (graph wise) was actually the 4th run, on the actual third run he let it set with engine off and fans on for about the same amount of time, almost 30 minutes between runs but it cooled off a lot faster than any of the other times. He ran the third one and HP had dropped to around 370 or so, the fuel had been bumped up to 6% at WOT for run 3 and 4. He let the engine idle and we got back up to operating temp and he did a forth run and we see with same 6% but engine temp back to normal range that the HP/TQ went back up some. Right now the WOT fuel percentage is at 4%, but I had changed that after coming home, 6% as we see was a bit rich and it just felt doggy at that level. I am not sure what tip is as I am not mechanical or technical, I just know how to install a few parts here and there, but I am guessing tip is what the tuner dude would have to adjust? thanks
