Spark Plug Gap?
Old May 30, 2009 | 09:32 PM
weazel's Avatar
Registered User
Spark Plug Gap?
What is the correct gap on plugs for boosted motors?
Old May 30, 2009 | 09:58 PM
Windsor's Avatar
.035"
Old May 30, 2009 | 10:18 PM
FX4 Matt's Avatar
Registered User
I have mine at 32
Old May 30, 2009 | 10:41 PM
weazel's Avatar
Registered User
So what would be the better gap then.032 or .035
Old May 30, 2009 | 11:28 PM
dirtyo2000's Avatar
i have mine set at 32. cant say what is best but i think everyone that i know has theirs at 32. if you have stock coils i would defintely do 32. i have gms and i had mine at 35 and was getting a slight miss sometimes. went 32 and runs smooth as silk. you could always try both and see which works better
Old May 30, 2009 | 11:39 PM
weazel's Avatar
Registered User
How much boost are you running and what kit?
Having the wrong gap, can that cause you to loose spark and power?
Old May 31, 2009 | 01:56 PM
batn68's Avatar
I had the brisks at 35, prior to the dyno tune Troyer advised me to re-do em at 32, no issues at 32 so far, but they have only been on for a few months.
Old May 31, 2009 | 04:46 PM
weazel's Avatar
Registered User
Is smaller gap for higher levels of boost?
Old Jun 1, 2009 | 10:13 AM
FATHERFORD's Avatar
32 is what i run
Old Jun 1, 2009 | 04:28 PM
dirtyo2000's Avatar
i have the roush ported 10lbs. thinking about 12 but mike keeps telling me no lol. once i finish my motor that im building and drop it in im going to run about 15 and see what this little charger will do before i spend the money on the whipple.
Old Jun 1, 2009 | 07:29 PM
GerRod's Avatar
I talked to Mike about this as well and he didn't like the idea. However, I'm tempted to "test" a +4 lb (Lightning) pulley in this 90+ degree heat, data logging the runs with my Innovate wideband. Supposedly, the +4 lb will give you about 3 lbs due to the Lightning having a smaller upper pulley than the 04+ Roush kits. That would put me around 10 psi total.
