supercharger
Google is your friend.
Looks like there setup for mustangs.
http://shop.torktech.com/index.aspx
Phil
Phil
99-04 GT Supercharger-less Kit Using a '03/04 Cobra Blower
Your Price: $1,899.99
Spacers To Adapt The TTI Lower Manifold To A 5.4L Engine (Pair)
Your Price: $195.99
3-Valve Side Manifolds To Convert a 2-Valve Lower Manifold (Pair)
Your Price: $345.99
These parts will start you off with the lower manifold you would then need to buy a supercharger i would suggest finding a low mile lightning m112 eaton that would bolt right up to this set up and use the lightning throttle body and neck that will also bolt right up to your m112 so you would have a cobra supercharger set up with the lightning intake so you wouldnt even have to worry about the rest of the mustang kit and re routing the intake ect. your biggest difficulty would be finding a correct size belt because this is a one off custom s/c build up.
then there is a long list of other parts depending on what horse power range your looking for most people around here stick with a 42# injector and 90 mill maf, larger fuel pump with custom tunes.I went with Troyer
you would need a intercooler, elct water pump, coolant tank, ect that you can get cheap used from people that have upgraded to aftermarket parts and sell then on ebay or this forum also look in the cobra and lightning forums for any ods and ends "IE" lightning coolant tank for intercooler. I just picked one up for 20 bucks on ebay.
I think it would be very possible to put a sweet kit together for you and fairly cheep if you play your cards rite.
