Custom S/C idea.
Old Dec 10, 2008 | 08:33 PM
IR0NS1N's Avatar
Custom S/C idea.
Ok so my problem is when I start getting my built block I want to run between 15-20 PSI on my whipple. In order to do so I need some custom stuff in order to run a 2 belt system. What I need are either some pictures and or part numbers off the roush set up. Basically I need to know on the roush:
1) Is the supercharger pulley 6 rib?
2) In order to put up the bracket which puts tension on the S/C belt, do you have to modify anything? Is the bracket need another peice or bracket in order to move something for clearence?
3) Does the bottom pulley interchange with the L pulleys? Where do you get the difference size crank pulleys?
And then the ultimate question, If I was to take the snout off a Lightning 140AX whipple and put it on mine in order to push the pulley farther out so it could be put on a the roush set up.
Im looking for pictures and part numbers to if you guys can get them. Im actually thinking it should be quite easy to do.
Old Dec 10, 2008 | 09:01 PM
IR0NS1N's Avatar
I wonder why you cant just to a stock L set up and convert it over?
Old Dec 10, 2008 | 09:11 PM
GerRod's Avatar
Here are some pictures.
https://www.f150online.com/forums/20...ally-done.html
Search on rafa26's threads. He's done just about everything you can think of.
Old Dec 10, 2008 | 09:20 PM
IR0NS1N's Avatar
So he has the roush upper which looks alot like stock L. Amazing heat exchanger too!
