Best plugs for 5.4 Procharger Setup?
Old Dec 2, 2008 | 12:15 PM
Chris123NT's Avatar
Hey guys, A couple of months ago I did a procharger on my 2002 5.4 and it's been running great with one exception. Ever since I did regular copper plugs (gapped at .038) it has been shuddering at idle. Really hard to explain but it feels like the engine is missing randomly, but it never throws a code. It never did this with the factory platinums, but obviously platinum + boost = no no.
Advice?
Old Dec 2, 2008 | 12:39 PM
Veteran: Army
I'm running the plugs for a 2001 lightning and i have no issues. when is the last time you changed your cops? are you on the FMU still or on fuel mods and a tune?
Old Dec 2, 2008 | 01:26 PM
Chris123NT's Avatar
Still on the FMU setup, gonna do a tune in the spring. But I know that isn't causing it since it was fine at idle when it still had the stock plugs (yes I forgot to do the plugs for the blower, stupid me lol). Once I did the copper cores the thing started idling weird.
Old Dec 2, 2008 | 02:53 PM
150xlt's Avatar
I run NGK TR-6 plugs
Old Dec 2, 2008 | 03:08 PM
boss1984's Avatar
+1...i use it for nitrous because im not blown...
Old Dec 2, 2008 | 03:15 PM
Veteran: Army
those are the same plugs i'll be switching to with the 3# crank pulley a lot of people run them with good results
Old Dec 2, 2008 | 03:34 PM
black02eb's Avatar
I was running NGK TR6's on my Procharged 4.6 at 12psi with no problems and will be running them again in the 5.4 DOHC when I get the charger back on. GOOD PLUG!
Old Dec 2, 2008 | 03:40 PM
Chris123NT's Avatar
Cool guys, thanks. I'm gonna order a set of those then. What do you guys gap them to out of curiosity?
And can someone give me a part number? Every time i search TR6 I see a copper core plug, unless that's the right one...
Old Dec 2, 2008 | 05:13 PM
black02eb's Avatar
The TR6's are a copper core plug but they are resitor type plugs. As for the gap, I set mine to 0.32 - 0.35 but the bigger the better without spark blowout under boost.
Which copper plugs do you have in your truck now?
Old Dec 2, 2008 | 06:56 PM
boss1984's Avatar
.032..wow..that seems kinda close..no?..i gap mine at .038 with a 175 shot
Old Dec 2, 2008 | 07:37 PM
Chris123NT's Avatar
I currently have a set of autolite copper core plugs gapped to .038.
Old Dec 2, 2008 | 08:58 PM
Z7What's Avatar
Im running TR6's gaped at .036 at around 12# of boost.
Wayne
Old Dec 2, 2008 | 09:58 PM
justjames80's Avatar
Motorcraft copper plugs gapped at .040.
Old Dec 12, 2008 | 11:34 AM
Memo21687's Avatar
Whats the difference between the TR6 and the TR55....NGK says that the TR55 is the size that fits my truck???
Old Dec 12, 2008 | 03:16 PM
Veteran: Army
Originally Posted by The Swede
hope that helps
