front mount turbo systems $4200 installed
If I had the money to spare I would get one in a heartbeat. I have a 99 f150 supercab with the 2v 5.4. What kind of power increase would I see from 260/350? I was playing with the idea of getting a lightening engine with low miles when this one bites the dust but seeing as it only has 89,000 miles....that could be a while lol
You could probably add anywhere from 120 to 150 to both of those number and make them at the wheels with around 8 - 9 psi. I seem to remember he PTK kits making close to 400 rwhp under 10 psi.
Look's like a nice kit.
What are the HP Gain's on a stock 5.4 with 300+ HP?
If you want to double the HP then you will need Forged Piston's and Drop the Compresion Ratio. You can get away with a de-comp plate between the block and head for moderate gain's.
Tried this out on smaller 2.0 Ford Zetec engine's and you will melt a stock piston if the HP is doubled.
Engine will be fine (if the tune is good), your transmission will suffer.
Tires probably won't be too happy either. C'est la vie.
