07 Cobra supercharger on a 00 5.4 2v?
Old Apr 4, 2008 | 03:03 PM
BLUE20004X4's Avatar
Quick question, can the blower off a new Cobra bolt onto a Lightning lower intake or is there too much else to change? I wasn't sure on the rear where the intake would connect to but mainly the front snout, how bout on a 08 5.4 3v?
Old Apr 4, 2008 | 03:18 PM
joshmac4.6's Avatar
New Cobra??
Old Apr 4, 2008 | 03:27 PM
azmidget91's Avatar
Originally Posted by joshmac4.6
New Cobra??
some people reffer to the gt500 as the new cobra
Old Apr 4, 2008 | 07:14 PM
Cypress700's Avatar
This is a good question for a Pro.I have an 05 F150 and would love to adapt the Eaton 122 to it.I have a spare supercharger,From what I hear the heads would have to be changed to wider 4 valve heads,And I do not have the intake manifold which houses the intercooler.Also it seems there might be a geometry problem with the 10 rib belt as the cobra belt runs off of the crank pulley behind the accessory belt-So there would be pulley changes.If I could do this economically I would.Running about 13 pounds of boost on my 2008 GT-500 created alot of traction problems!!!
Old Apr 5, 2008 | 01:50 AM
justjames80's Avatar
More trouble than it's worth to put a Eaton R112H from a GT500 onto a 3V 5.4L. Better off working from an existing kit that already supplies the cast lower manifold.
Old Apr 5, 2008 | 10:11 AM
I figured as much, my dad upgraded so here's a supercharger going to be just kicking around. I've got the 00 and my brother has an 08, but I think I'm still going with the Procharger..............that is when I get rich.
Ya, I call it a Cobra more than a Shelby because there is about 10 snakes on this thing.
Old Apr 5, 2008 | 12:25 PM
khendrix2374's Avatar
No, the blower will not fit the 2V cylinder heads of your truck.
pull the engine, replace the connecting rods and pistons, bet the belt set-up and intake manifold from a cobra and you're golden!
