ever hear of a Ice box?
Old Apr 3, 2008 | 03:44 PM
weazel's Avatar
Registered User
Originally Posted by phil6608
Yes
http://www.jegs.com/i/Nitrous%20Expr...00-05/10002/-1
Or you could just get a bottle,,put a hose on it and spray it after a pass.
Little less expensive that way...lol
Phil
so chilled water will work?
Old Apr 4, 2008 | 03:20 AM
justjames80's Avatar
Originally Posted by weazel
just out of curiosity, can you spray the heat exchanger with water or nitrous after a run on the strip?
Wouldn't be doing any good after the run. Air-to-air intercoolers don't suffer from heat-soak like air-to-water setups do.
Old Apr 4, 2008 | 08:33 AM
built54's Avatar
yeah i wouldnt waste time spraying the intercooler
Old Apr 4, 2008 | 04:05 PM
weazel's Avatar
Registered User
mines air to water..,
Old Apr 4, 2008 | 04:12 PM
azmidget91's Avatar
well if you havent figured it out yet, for yours it would basically be like a kegerator (haha) your intercooler fluid would go through the ice box (through tubes inside) and it would cool the fluid then cool your ic even more
o and what he meant by getting a bottle and put a hose on it i believe he meant get a nitrous or co2 bottle and have a hose on it to spray it on the ic, which is basically the same as those expensive nitrous kits out there
but yes you could through some chilled water on it to cool it off but this may cause it to crack, so do little bits of water at a time, not just dump a 5 gal bucket on it
Old Apr 4, 2008 | 04:23 PM
weazel's Avatar
Registered User
ah see thats the explaination i was looking for..... does the box go before the IC or after?
Old Apr 4, 2008 | 04:29 PM
azmidget91's Avatar
see you just get lost when you cant im me because of my computer crashing
id say after though cuz that is when it is the hottest and its better to get it cooled down before returning it to your system
