ever hear of a Ice box?
Old Apr 2, 2008 | 09:49 PM
weazel's Avatar
Registered User
ever hear of a Ice box? suppose to lower temps of the inter cooler?
Old Apr 2, 2008 | 09:56 PM
OrdnanceCorps's Avatar
Not me.
Old Apr 2, 2008 | 10:22 PM
joshmac4.6's Avatar
Yea Its where you put the beer , oh you mean a ice box for the intake. Yeah, its easy, make a sheet metal box, run a some charge tubing through it and fill it up, dry ice works best, but they work great. I packed my intake with ice last time at the strip. IAT w/out Ice=114 F IAT w/ice=72 F, it makes a big difference.
Old Apr 2, 2008 | 10:24 PM
Veteran: Army
or
it's a degas tank that alows you to add ice directly to the innercooler fluid and then drain it back out after each run to add more ice
Old Apr 2, 2008 | 10:44 PM
built54's Avatar
yeah i have a 3 gallon tank with a drain valve. fill it with ice, make a run, drain, fill with ice, and make another run. very nice to have.
Old Apr 2, 2008 | 10:49 PM
joshmac4.6's Avatar
It's horsepower in a box, get one
Old Apr 2, 2008 | 11:49 PM
FX4 Matt's Avatar
Registered User
I did look into getting one but its hard to find a place to put it under our hood, so I just added another heat exchanger
Old Apr 3, 2008 | 12:56 AM
weazel's Avatar
Registered User
any one have pics of this ice box setup, not really getting it?
Old Apr 3, 2008 | 01:33 AM
Klitch's Avatar
whats not to get? the ice cools the air before it goes in, making it denser, more power n so on.
Old Apr 3, 2008 | 03:34 AM
weazel's Avatar
Registered User
no ****.... no need for the rudeness... what i don't get is how it is set up....
Old Apr 3, 2008 | 05:19 AM
justjames80's Avatar
There's a couple of ways of doing this. If you are running an air-to-water intercooler setup then the ice-box is a tub that surrounds the reservoir for the intercooler fluid. For air-to-air setups it's worthless as chilling the charge piping makes little difference to the air temperature after it leaves the intercooler. Better off with nitrous, water/meth injection, or a spray bar for the IC. last version is where the fuel lines are coiled inside of a tub which is then filled with ice. Chills the fuel which aides which helps prevent knock slightly but is mostly to prevent vapor lock from boiling fuel. More of an issue with race fuels that pump gasoline though.
Old Apr 3, 2008 | 08:36 AM
built54's Avatar
Here is mine. What battery?
Old Apr 3, 2008 | 12:17 PM
phil6608's Avatar
Not a new thing.
JLP sells 2 different ones.
I believe they work kinda like a refrigerator...lol
http://www.johnnylightningperf.com/s...products_id=16
http://www.johnnylightningperf.com/s...products_id=17
Phil
Old Apr 3, 2008 | 02:05 PM
weazel's Avatar
Registered User
just out of curiosity, can you spray the heat exchanger with water or nitrous after a run on the strip?
Old Apr 3, 2008 | 03:18 PM
phil6608's Avatar
Yes
http://www.jegs.com/i/Nitrous%20Expr...00-05/10002/-1
Or you could just get a bottle,,put a hose on it and spray it after a pass.
Little less expensive that way...lol
Phil
