Wideband readings
Wideband readings
So I installed my xd-16 and still waiting on my tunes from troyer but need help reading my wideband.. Witch side is lean the bigger the number or smaller?? Till I get my tune what is acceptable A/F #'s to run at with out popping
Thanks for any help
Thanks for any help
the higher the number the more lean
the lower the more rich
at idle mind reads 14.8-15.2
if im just crusing it reads 14.5-14.8
at wide open throttle it reads 11.4-11.8
richer is better but too rich is bad.
The wide open throttle #s are what you need to watch and worry about!
If your seeing much over 12 or 13. Let off of it!!!!
My truck runs right on 11.5 at WOT.
I could go a little leaner but that's my safe street tune.
Phil
Phil
Originally Posted by built54
Wow I thought i was on the safe side of 12.0-12.2 at wot... maybe Ill lean it out a little.
Originally Posted by Neal
HI!... You meant richen it up right? Your current WOT #'s would be o.k if you were running meth. But if your just running the SC'er with no meth then I wouldn't go leaner than 11.85 A/F.
K- guys just got back heres what my XD recorded (did a free air cal just before I left)
idle 14.0-15.2
cruise set @ 53 on a some what flat road
14.0-15.3
WOT 10.1- 11.2 looks like im a little too rich a WOT
this is with a FMU still What do you think am I ok?? or should I stay away from my truck till I get tunes
tunes on the wayyyyy
idle 14.0-15.2
14.0-15.3
idle 14.0-15.2
14.0-15.3
idle 14.0-15.2
14.0-15.3
....Can't wait for my tune's I will take the truck for a spin later and post what I see...
