Testing Interest: STS Turbo Kit
Old Mar 31, 2008 | 12:57 PM
tj03f150's Avatar
Originally Posted by joshmac4.6
Makes perfect sense, I was looking at possible mounting it in the front bumper, but once again, can't find anywhere to run that downpipe. But I still can't PM, but send some to my email if you don't mind. joshbramac@yahoo.com
email sent.
Old Mar 31, 2008 | 01:04 PM
joshmac4.6's Avatar
Hey thanks, it looks good, I understand the ground clearance problems alot better now, those are really low. I like you setup though, its a good idea, and really keeps everything compact.
Old Mar 31, 2008 | 01:07 PM
tj03f150's Avatar
thanks, i also did it this way so i woudlnt have to pull the motor.
if i ever ewant to go back to stock... it'd be very easy.
Old Mar 31, 2008 | 01:13 PM
joshmac4.6's Avatar
Yea nothing that requires too much wrestling. I'm sure you have seen the grabber f150, but that is what I would like to see how they did the setup on, and there is also a guy who did a 4v Expy, like to see his setup as well.
Old Apr 1, 2008 | 04:16 AM
Tornadom's Avatar
Lot's of new posts in here today.
How remote is the the STS kit? I probably wouldn't be interested if there was more than 1psi pressure loss between the compressor and the throttle body. It is looking more and more like I am going to be piecing together my own kit and having someone fabricate the manifolds for me. I am looking to build the internals and transmission and would like to see 500rwhp on pump gas.
Old Apr 1, 2008 | 09:04 AM
tj03f150's Avatar
the turbo on an sts kit is mounted in place of your muffler.
the only thing i dont like abou an sts kit is that u have to have an oil pump to pump the oil from the turbo back to the oil pan. just one more thing to fail.
Old Apr 1, 2008 | 09:41 AM
Tornadom's Avatar
I would likely modify the kit so that the turbo has its own dedicated oil supply. Make a tank that tucks up under the frame nicely, add filtration to it and wire in a nice electric pump to keep things cirulating. I guess an oil cooler with a fan would be a good idea as well, but that is all nominal.
