those w/boost & stock internals? post here
![Exclamation](https://www.f150online.com/forums/images/icons/icon4.gif)
If you are supercharged or turbocharged with stock internals please post here and specify if you have a supercharger or turbocharger, how much psi your running and if you tuned with sct, diablo, sniper or any other tuning. oh and please specify if your running a bigger fuel pump, bigger injectors and bigger maf or an FMU. and also what motor you have...
Just trying to see how many out there have forced induction on a stock block.
I'm finally getting my Turbocharged 2003 4.2l v6 f150 dynotuned tomorrow and its scaring the sh*t out of me...
I've got 56k miles on my 2003, its got 39lb injectors, 90mm maf, 255lph walbro fuel pump, blowoff valve is vent to atmosphere and the maf is blowthru.
I've got a boost/vacuum gauge, fuel pressure gauge, and wideband gauge.
Stock 01 5.4 with 01 lightning manifold, injectors, SC, oversized Bosch 255 lph fuel pump, programmed with SCT Xcalibrator 2
10 PSIG boost
150K on the motor - 35K with the SC installed. Daily Driver
Lean conditions kill blown motors. Make sure you get a wide band air/fuel check during your dyno runs.
10 PSIG boost
Originally Posted by tj03f150
anyone know what should the wideband a/f read?
Originally Posted by ONELOWF
Driving around under light to moderate throttle ( closed loop ) you should see mid 14's. On the gas and under boost you should see the a/f's transition to mid 11's ( open loop ) - this can occur as late as 3,500 rpms in a run. If you are seeing anything more than 12, back off, it is too lean and more fuel is needed.
that is weird okay so under light load its okay to be at 14 but if im in boost it should never go over 12 and should stay around 11.5?
Yep, when you start increasing the cylinder pressure you want more fuel. Enough good fuel will save your engine. I always tuned my stuff for 11.8 A/F. I will most likely tune this truck for closer to 11.5 A/F when I get my S/C. Rich is WAY better than lean when you are boosting a naturally aspirated motor.
