Gauge options for supercharged F150
Old Dec 9, 2007 | 11:14 PM
madferraristi's Avatar
Originally Posted by FX4 Matt
I got the mount from jegs or summit for like 45 bucks, the paint I got online I'll post the name of it when I find it
You can go to your Ford dealer and buy a can of spray paint formulated to match your interior. Many parts countermen don't know it exists, I'll try to remember to post up the part number for the color that matches my interior. That will at least get him into the correct group, then you can give him the year and interior code or color name for your truck. The paint matches well and sticks well also.
Old Dec 9, 2007 | 11:53 PM
justjames80's Avatar
Originally Posted by madferraristi
The two most important gauges for those on a limited budget are Boost and Fuel Pressure. An Innovate Wideband is highly desirable.
Piggybacking on Mr. Dunn's post the Innovate Motorsports widebands are nice. Well worth the expense if you plan on getting serious with a power adder. They have a line of gauges and setups depending on how much data you need to collect. They have gauges packaged with controllers that not only let you get accurate A/F readings but will datalog so you can review the info on your computer.
Old Dec 10, 2007 | 01:18 PM
OK, here you go, as promised.
For my 2002 Supercab I have, from the label on the can:
M4JZ-19M547 4253-H DARK GRAPHITE INTERIOR.
Old Dec 24, 2007 | 09:43 AM
riceh8r's Avatar
Boost, fuel pressure, & Innovate MS Widebands are the most accurate widebands you can use.
