Supercharger/ Tuner/ Module
Old Jul 21, 2007 | 09:47 PM
varsitymojo's Avatar
If I put a supercharger or a Turbo Charger will I still be able to use a Tuner or a Jet Prformance Module on my Truck? And If I do put some kind of Forced Induction on my 4.6L What else will I need to do to my truck to get it to run correctly?
Old Jul 22, 2007 | 12:57 PM
adt's Avatar
adt
Nope, you have to get a custom tune and use a flash tool like the SCT Excall 2 or the Preditor, chips won't work. As far as other stuff you'll need, more than likely larger injectors, MAF, and maybe a larger fuel pump. The most important thing is the tune, without that you'll be shopping for a new motor very soon.
Old Jul 22, 2007 | 01:02 PM
built54's Avatar
A custom tune is a must. I Would never trust an off the shelf tune for boosted apps.
Old Jul 22, 2007 | 01:07 PM
crash_lucky13's Avatar
not only that, some programmers won't work period. I know on Hypertech they couldn't retard my timing enough....
Old Jul 22, 2007 | 01:15 PM
I already have the Jet Performance Module and The Edge Power Programer. I know I still need a tune but can I still use these two things? As for injectors and a high flow fuel pump can anyone tell me where to pick them up at? And what size/ brand injectors are good to go with? And same for the fuel pump.
Old Jul 22, 2007 | 03:00 PM
built54's Avatar
you need to ditch those two and get a custom tuned xcal II. What do you want to do? how much boost?
Old Jul 25, 2007 | 09:58 AM
Veteran: Army
http://www.buyfordracing.com/shop/pr...roducts_id=623
and some kind of 255lph fuel pump and you'll be all set
