lightning swap fuel pump ???
Old Jul 13, 2007 | 01:03 AM
Eric2000F150's Avatar
I'm about to do a lightning blower swap on my 2000 F150. I have already bought the supercharger set up with most everything I need. What type of fuel pump do I need? I'll run #42 injectors and it will be pullied for 12 psi. Will one 255lph pump be efficient? I may buy the comp cams xe 262 cam shafts but I have not decided yet.
Eric
Old Jul 14, 2007 | 10:38 PM
03expyeb's Avatar
mike dunn at madenterprise can confirm everything for you, but you should be all set imo. i have a similar setup and have no issues with a 255 bosch pump.
Old Jul 16, 2007 | 09:51 AM
bigtruck311's Avatar
255LPH will work fine
Old Jul 17, 2007 | 10:38 AM
brahmus's Avatar
one is rated for about 500rwhp.
Old Jul 19, 2007 | 12:05 PM
1JT's Avatar
1JT
Instead of starting a new thread I thought I would just add to this one.
After putting in the Bosch 255, does the running of the pump seem louder then the stock or is this a precursor to a failure.
Old Jul 19, 2007 | 12:20 PM
brahmus's Avatar
How long has it been in there? You can hear a 255 bosch, but only if you are listening for it. Mine got louder as it began to fail but only after 10K miles or so. When I first installed it, it was loud, it was to low in the tank and resonating off the bottom.
Do you have a fuel pressure gauge?
A/F gauge? Any drivablity issues?
How did you wire the bosch?
Old Jul 19, 2007 | 01:22 PM
1JT's Avatar
1JT
It has about 400 miles on it. It was wired per Mike Dunns instructions. No fuel psi gauge and no drivablity issues
Old Jul 25, 2007 | 09:59 PM
03expyeb's Avatar
mine is pretty loud, but no drivability issues. been installed since early february. i thought it may failing too, but one of the techs at work says it just isn't insulated well enough and i hear the vibrations.
