heat exchanger options
Old Jul 8, 2007 | 12:53 PM
built54's Avatar
Doing the L conversion with built engine on my f150, and the factory h/e from a lightning wont fit up front with my bumper brackets, so I have to look at other options. I would like any advise you have. I have found this: eBay Motors: liquid to air intercooler radiator turbo supercharger (item 150137604129 end time Jul-29-07 20:02:51 PDT)
3/4 in/out fittings, It could be mounted in front of the radiator, would this be efficient?
Old Jul 8, 2007 | 08:46 PM
ONELOWF's Avatar
You could mount the HE flat rather than vertical under the frame rails, plenty of ground clearance. With a pair of efans pulling the air through from the bottom, or pushing from the bottom up. I see that some of the newer trucks have them in front, but I wouldn't.
I beleive chucks_bp and WLF are both using the L HE on F150's but 2wd, ask them.
Old Jul 9, 2007 | 10:04 AM
madferraristi's Avatar
I have heard before that the OE Brackets do not mount properly to the back of the '97 & '98 bumpers, I must assume Ford made a change in '99.
If I were you, I would try to stay with an OE (or direct aftermarket replacement) as they are sized for optimum performance. Fabricating a couple of brackets should not be that difficult.
Old Jul 9, 2007 | 10:45 AM
bigtruck311's Avatar
i agree with mad, using a factory style HE and fabricating your own brackets wont be that hard at all
Old Jul 9, 2007 | 01:55 PM
built54's Avatar
yea that wouldnt be a problem. My bumper brackets that are on my truck now do not allow the h/e to fit behind the bumper. Its just too wide. If it was the h/e brackets, i would fab something up.
Old Jul 9, 2007 | 04:25 PM
chucks bp's Avatar
When I installed my heat exchanger, bought a used one on eBay, I thought the Ford OEM brackets were too expensive, I made my own brackets in less than an hour, used the bumper bracket bolts and stock heat exchanger rubber mounts, I believe that it gets very good air in that lower location, I might add that I used stock Lightning pump and bracket and all stock molded hoses. everything fit perfectly, and works very well. I am seeing a max temperature of 10 degrees over ambient and usually less during cruise, it will rise 15 or 20 degrees during boost but cools down quickly. My highest air-charge temperature on an 80 degree day was 104 at 9.5# boost.
Old Jul 9, 2007 | 05:42 PM
Klitch's Avatar
eh? doin the same thing here, theres a rubber mount system? anyone got a pic of how thats setup? dont wanna hard mount it.
Old Jul 9, 2007 | 06:34 PM
Neal's Avatar
Cool
HI!... This bolts in with "MINOR" (LOL) modifications.
Old Jul 9, 2007 | 11:13 PM
built54's Avatar
haha yea Neal, Maybe if I was doing a turbo
Old Jul 10, 2007 | 10:37 AM
maybe you could change your bumper to the 01 and up style? would that fix the problem?
Old Jul 10, 2007 | 02:00 PM
built54's Avatar
yeah that would fix the problem, but I would need the bumper, brackets, grill, grill shell, fog lights, and the lower valance. about $500
Old Jul 14, 2007 | 10:39 PM
03expyeb's Avatar
i havent forgot about the pictures i said i would send you(on another site)....just with work and then a two year old.....! i will try again tomorrow.
