Single 2 1/16" gauge pod
Old Jul 11, 2007 | 01:09 PM
Marc Carpenter's Avatar
I have looked everywhere I can think of for a single gauge (2-1/16") pod.
I don't care if its an A-pillar or column mount as long as it will mount properly in my 2004 Supercrew. I will be adding a Roush S/C to my current list of mods on the 25th of this month and want to install a "single" boost gauge. Anyone have one or seen one???
Old Jul 11, 2007 | 02:55 PM
SLRFX4's Avatar
Marc,
You might try these guys....
https://www.f150online.com/forums/li....com/ford.html
Old Jul 11, 2007 | 11:10 PM
ONELOWF's Avatar
I have a single column pod that looks oem. I'm not sure if they are available for the 04+.
Old Jul 12, 2007 | 05:17 AM
khendrix2374's Avatar
Any city between North Canton and Virginia that has an O'Reilly Auto Parts store...
I've been to three in my area and they have an entire section of gauges.... ON second thought.. I know 2 out of 3 have a whole wall of gauges.. the other one I'm "mostly" sure has some too.
2" boost gauges.. either white faced or black faced.. carbon fiber faced.. mechanical or digital.
Old Jul 12, 2007 | 09:44 PM
tigerballz88's Avatar
The little change holder off to the right of the steering wheel (if you have one) is a perfect spot to put one gauge. It's circular and it pops out. I had an Autometer gauge put in that spot and it fit like a glove. No modifications.
Old Jul 12, 2007 | 09:45 PM
The little change holder off to the right of the steering wheel (if you have one) is a perfect spot to put one gauge. It's circular and it pops out. I had an Autometer gauge (2 1/6") put in that spot and it fit like a glove. No modifications. It looks like it came from the factory!
Old Jul 12, 2007 | 09:49 PM
sorry about the repeat posts
Old Jul 13, 2007 | 08:05 AM
Thanks for everyones input.
I found resolve by purchasing a dual A-pillar pod and adding an oil pressure gauge in conjunction with the boost gauge. Now I have somenting to occupy my Saturday morning with. I will install both tomorrow and just leave the boost line coiled up under the hood until I install the blower in two weeks....
If anyone is looking for Autolite Revolution HT0's, I just picked up two sets from Summit Racing last week. They seen to have a healthy stock @ $9.95 each. Also installed new fuel filter and 02's, plus changed the rear end lube over to Mobil One synthetic 75-140 with a bottle of friction additive. Ready for the blower now....
Old Jul 14, 2007 | 10:28 PM
03expyeb's Avatar
pics?
Old Jul 14, 2007 | 10:37 PM
03expyeb's Avatar
Originally Posted by SLRFX4
sent them an email. looking for a single pod for my a-pillar, but have yet to find anything yet. not 100% sure if the 04+ f150's have the same a-pillar moulding as my 03 expedition(new body style looks like an 04+ f150).
Old Jul 15, 2007 | 12:22 PM
What a pain in the @ss trying to stuff all the wires and the vacum line through the dash and into the engine compartment. Both my'01 Lightning and '03 Cobra had easier access to route the wires....but the end result is worth it I guess....I added an electric oil pressure gauge also, and you have to be very carefuly running the wire to the sending unit.. I had an oil leak that was driving me insane before the installation and I found it very easily while installing the new sending unit. The stock sending unit was finger tight and only had 3 threads holding it...Oil was squirting out around it and causing a slow drip when the truck has parked overnight. Not anymore--
