lightning swap complete, no power
Old Apr 30, 2007 | 06:32 PM
  #31
Jordan not Mike's Avatar
Originally Posted by bigtruck311
this is a tuning issue correct? there is nothing i could have installed wrong to retard the timeing. it almost feels like a slight miss but it only feels that way at over 1/3 throttle were i can barely tell with all the engine noise and blower wine, well i geuse i will find out tommarrow when i get on the dyno, i just hope nothing breaks, i have bad feeling about going full throttle under load if something is wrong. anything more i can check before tommarrow mourning?
Yes, that would be tuning, although a bad knock sensor could be pulling it back (this would throw a code, though)...I think excessive IATs could as well, but I can't imagine your IATs could be sky-high.
I wouldn't go full-throttle on the road until you get it resolved. When you are on the dyno, I think this will all work itself out. Are you just putting it on a dyno to log data, or do they have the equipment to alter your tune as well?
Old Apr 30, 2007 | 07:49 PM
  #32
bigtruck311's Avatar
they should have all the equipment to alter the tune they are a authorized super chips dealer, so i would assume so, i geuse i will find out tommarrow, on the question about the intercooler routing, is this how yours is set up(asuming of course you have the same type of blower setup as me)
Old Apr 30, 2007 | 08:27 PM
  #33
Sorry bro, I've got a Procharger.
Old Apr 30, 2007 | 08:48 PM
  #34
MGDfan's Avatar
I mentioned that earlier - Lightnings don't have knock sensors since they cause false knock detection & pull timing. So, I'm assuming any lightning blower swap into a non-lightning application would have those inputs disabled in the tune. Is this correct?
Old Apr 30, 2007 | 09:12 PM
  #35
i think the lightnings have knock sensors, i used a lightning engine wireing harness for the install, and it had the inputs for the sensor, so i am assuming that is not the problem, and as long as it isnt knocking that shouldnt cause a problem any way(hopefully)
Old Apr 30, 2007 | 09:23 PM
  #36
Sometimes the knock sensors will interpret other noises (blower rattles, etc) as knocking, and pull timing. This was the case with my noisy Procharger, so we disabled the sensors....freed up a lot of power but I need to be mindful of detotantion.
Old Apr 30, 2007 | 09:27 PM
  #37
MGDfan's Avatar
BT - I don't think so. They'd get fooled by all the 'noise' created by the blower mechanicals ( the sensors are acoustic transducers). So L's don't have 'em. So they would be telling the PCM to pull timing even during normal operation. That's also the reason that any sort of detonation in an L is real bad news, since there is no 'safety net'. ..
Originally Posted by Superchips_Distributor
... And of course virtually all computer controlled gas-engine vehicles have active knock sensor systems (Ford's factory-supercharged 4.6 Cobra & 5.4 Lightning & Harley being rare exceptions), so as long as any detonation is within the system's effective compensation range, you won't hear audible detonation as knock retard is taking care of it.
Old Apr 30, 2007 | 09:39 PM
  #38
BT - I don't think so. They'd get fooled by all the 'noise' created by the blower mechanicals ( the sensors are acoustic transducers). So L's don't have 'em. That's also the reason that any sort of detonation is real bad since there is no 'safety net'. Can someone else confirm this?
i hope this is not the problem as i would have to take alot apart to be able to get to that connector, i just think it is weird that a lightning wireing harness would have the inputs for a knock sensor if it doesnt need it, this would have been good to know before i started the install, if this is the problem i am hopeing it shows up on the datalogging process, i dont care if i have to tear the whole engine down i just want to be able to know for sure what the problem is.
Old Apr 30, 2007 | 09:46 PM
  #39
MGDfan's Avatar
BT - I edited my last post. Sal should be able to turn them off in the tune, if that is indeed your problem - not sayin' it is, just tossing out ideas, bud.
Good luck
Old Apr 30, 2007 | 09:48 PM
  #40
I think the dyno time will be well-spent.
If it is a knock-sensor issue, they can be turned-off via the tune.
So long as your install went right, you should be OK.
Trust me, I feel your pain. I had a bad tune for a month in my daily driver, getting 6MPG, billowing black smoke and toasting my cats in the process.
But once it gets sorted out, you'll have a huge grin on your face every time you drive your truck. And you'll forget the PITA that you went thru to get there.
Old Apr 30, 2007 | 10:25 PM
  #41
Huitt24's Avatar
my truck had a COP going out that made the truck have a funny exhaust note once it started to see any boost. It would run fine up to about 3000RPM or when boost started building. It was my #5 COP that caused the problem and it did not throw any codes at all.
When you say it changes the exhaust note about what RPM's are you at? does it happen when you are reading boost on the gauge?
Old May 1, 2007 | 07:13 AM
  #42
CobraKit's Avatar
I believe L's have relocated knock sensor on side of block vice in valley, which would be directly under blower. SAL turns it off when you get his tune for 150's which L/HD blowers.
Old May 1, 2007 | 07:51 AM
  #43
MGDfan's Avatar
If the do have them (and I still do not think true L's do - see MT's & these two posts for the Lighnin' forum), relocating them would make no difference; the block is a great conductor for sound. Put 'em anywhere on that block & they're gonna 'hear' all the racket .
Originally Posted by EnglishAdam
You can detect [detonation] when it happens because the rods come shooting out of the side of the block
IIRC, there's nothing in the datalogging program that tells you there is detonation. The knock sensor is not connected on the supercharged engines as the harmonics are too sililar to the noise from the blower.
Watch the a/f ratio, start with conservative timing and if it sounds like it's detonating, shut it down and start again.
Originally Posted by Struck in AZ
All well and good but L's don't have a knock sensor... I do agree with your assessment that he needs a new tune.
BT - when's your session hapening?
cheers
bubba
Old May 1, 2007 | 11:00 AM
  #44
madferraristi's Avatar
The Ford supercharged engines have the knock sensor in place and connected, however they are not programmed in the PCM.
On a stock engine such as yours, the sensor is connected and functioning. Some tuners find it necessary to turn them off in the tune to prevent them from pulling timing due to the blower noise.
When you look at your IC reservoir with the engine running, can you see fluid movement (bubbles, etc). If not, your pump is not running and will cause a definite power loss though not as extreme as what you are describing.
Your dyno session should give the answers.
Old May 1, 2007 | 11:41 AM
  #45
WLF's Avatar
WLF
I ran on a dyno with heat soak and the knock sensor connected and running in the tune. The program backed out 16 degrees timing. Beleave me that takes the power out of the engine.
I have a dedicated 7 inch Derale fan now connected to to the heat exchanger to prevent any heat soak. The tuner refused to turn off the knock sensor so I hooked the knock sensor pig tail up to an old sensor I had laying around in the garage and isolated it in the engine compartment inside some foam. That made a world of difference in the way the truck runs. I haven't been back on the dyno but my seat of the pants impression is worth smiling about.
