Do Superchargers and Warranties mix?
Old Nov 10, 2006 | 01:21 AM
Fireboy's Avatar
Question Do Superchargers and Warranties mix?
If I install a supercharger on my 2006 F150, will it void my warranty?
Old Nov 10, 2006 | 02:16 AM
justjames80's Avatar
That's one of those "it depends..." answers. Technically...no it shouldn't.
Legally, a vehicle manufacturer cannot void the warranty on a vehicle due to an aftermarket part unless they can prove that the aftermarket part caused or contributed to the failure in the vehicle (per the Magnuson-Moss Warranty Act (15 U.S.C. 2302(C)) .
That being said you can almost bet that a dealership will try to void either your powertrain or emissions system warranties if not both if you bring it in for any reason even if it's obvious the supercharger couldn't have caused the failure. Read everything on this page: http://www.granatellimotorsports.com/magnusonmoss.htm and take the info for what it is worth. May have to get tough and shove a copy of this document under a service manager's nose to get something done. I've had to do this with my truck once.
Old Nov 12, 2006 | 01:40 AM
flanaganman's Avatar
the roush will not void your warranty go to his web page check it out for your self
Old Nov 12, 2006 | 02:56 PM
05RoushMarkLT's Avatar
I've had the dealership do warranty work on my truck after the supercharger install, but it wasn't related to the supercharger. I've also ran into the same problem where I had a common problem on the F150's (slip yoke clunk), and they wouldn't fix it under warranty because they said it could be due to the added power destroying the driveline (which wasn't the case). I took it to a driveline specialty shop and had it fixed in half an hour and a tenth the cost of the dealership.
Old Nov 12, 2006 | 06:35 PM
pb4life's Avatar
If they prove the supercharger directly caused the problem then yes.
Old Nov 12, 2006 | 06:54 PM
inurok's Avatar
The ROUSH will void your FORD powertrain warranty but Roush itself will warrantee the powertrain portion themselves for 3/36,000 miles.
Question I have is can I go to ANY ford dealer or does it have to be a Roush authorised ford dealer for repairs?
Old Nov 20, 2006 | 03:42 PM
BABA4488's Avatar
This is a very good question/thread that i have been thinking about eversince i got my truck. But my main question/concern is-Inorder to not void your warenty does An authorized Roush or Whipple/Ford Racing person have to install the blower or can your install it yourself???????????
Old Nov 21, 2006 | 08:44 AM
inurok's Avatar
Yes an authorized Roush person have to install the blower.
Old Nov 21, 2006 | 03:17 PM
InstantGrits's Avatar
I am doing this now, as long as an ASE certified mech does the work Roush WILL warranty the work. If you dont believe me call Roush, I did
Old Nov 24, 2006 | 08:02 PM
inurok's Avatar
A Roush approved ASE certified tech I was told. Oh well
