supercharger thru the winter
Old Sep 12, 2006 | 03:13 PM
bb17's Avatar
Might be a silly ? but look'n for opinions. I live in Mass. and as you know it gets pretty darn cold in the the winters. Would the cold starts have any effect on a supercharged motor considering it's my daily driver? Anyone drive thru the winter S.C. ?? Thanks
Old Sep 12, 2006 | 05:25 PM
raider's Avatar
I drive my s/c truck in the winter here in the frozen tundra of North Dakota with no problems...you just dont go WOT on a cold engine
Old Sep 12, 2006 | 05:49 PM
MITCHYKINS's Avatar
MY charger makes some noise when it's 40 below but it
pretty much gets drowned out by the screaming of the power steering
mitch
Old Sep 12, 2006 | 07:18 PM
05RoushMarkLT's Avatar
This will be my first winter that I'll be putting my truck through as well with the supercharger. I'm a bit worried as I'm already pushing the horsepower envelope with what this engine can take, and the cooler air isn't going to help any. I don't plan on going WOT, but the RPM's can accidentally go up in a hurry when the roads are snow and ice for 6 months out of the year. I wouldn't be so worried if I parked in my garage, but I'm not done building it yet, so I'll have cold starts every day until I get moved in. Hopefully that will be before January and February when the real cold snaps hit.
Old Sep 12, 2006 | 08:37 PM
CDB03STX's Avatar
GOOD LUCK!!! I'm anxious to see 9#'s again. Since summer has come, all I see is 7 #'s, sometimes 8. Amazing what those other few pounds do
Old Sep 13, 2006 | 01:35 AM
I was hitting 9.5 pounds on the dyno in 99 degrees California heat. With air flow on the streets, I'm right around 10. Cool it down 150 degrees and I might be able to see some crazy boost. I gotta get my gauges hooked up so I can at least take a look where I'm at now with it being 30-40 degrees out. I can easily feel the extra power when the temps stick around there during the day. I wish I could just keep pushing it, but I know there is a breaking limit somewhere, and I don't want to find it.
Old Sep 13, 2006 | 11:27 AM
LTNDave's Avatar
just watch your boost, its not the cold, but what happens when the air is cold and dense, if you are running 10 lbs in 80-90 degree heat and it cools to 40-60 degrees you might see 13-14 lbs and if its colder than 40 it may go up to 18lbs +, I swap out my pulley in the winter to prevent this sort of over boost condition.
Old Sep 13, 2006 | 03:46 PM
inurok's Avatar
I have the Roushcharger and intercooler so I think I am capped at 6psi
Old Sep 13, 2006 | 06:32 PM
MITCHYKINS's Avatar
I only run 6 psi on my superscrew (lightning set up)
and that is plenty for the skinny ground grips and cold pavement
it's cool feeling when you do a 4 wheel burnout though
mitch
Old Sep 13, 2006 | 07:48 PM
FATHERFORD's Avatar
Yes, its amazing what cold weather does... I remember when it went from being 50degress one night, to 80 the next.....
I thought something broke
