Installing a boost guage?
Old Sep 8, 2006 | 07:34 PM
inurok's Avatar
Is it easy to install a boost guage in a Roush supercharged truck? Is it plug and play or do I have to do drilling etc?
Old Sep 8, 2006 | 11:46 PM
justjames80's Avatar
Drill and tap the oil pan....easy!
Seriously though...yes...very simple. Install a vacuum "T" fitting on a major vacuum source then get a rubber connection tube to connect the supplied nylon tubing to the fitting. Here's a pic of my setup:
The topmost fitting is for the boost gauge. Simple stuff you can buy for a few bucks at any auto parts store. Don't know if the new style truck have a main vaccum line like this behind the battery but it gives you an idea of what to look for. Do not tie into a source line used by the EGR sensor or any other sensor for that matter.
Old Sep 9, 2006 | 10:40 PM
inurok's Avatar
Thank you for the info and the image. I think I will buy a guage and try this week.
Old Sep 10, 2006 | 02:00 AM
RGCBSHRTY#1's Avatar
Just a heads up..
Make sure the source is seeing vac and boost. There are some that may only show vac.
Old Sep 10, 2006 | 01:35 PM
inurok's Avatar
Is there a hose the comes off the Supercharger that I would connect this too?
Old Sep 11, 2006 | 11:33 PM
98Navi's Avatar
Mine is connected right before the TB and works like a champ
Old Sep 18, 2006 | 11:07 PM
SuperSport1985's Avatar
Look for a red vacuum line that is capped off thats what the people at Roush told me and it works fine. I used an electronic boost gauge.
