just recieved my vortech kit,used,few questions
Old Aug 31, 2006 | 10:40 AM
one eyed willy's Avatar
for $1500 im not bitching,looks like the only things missing are the injectors and the programmer.
injectors are 39# cobra injectors from vortech,question is : should i just get those 39# ones or should i get something else since i am having to buy them anyway.
does anyone have good on-line directions or good pictures,tips on the install?
i will need a programmer with the vortech tune,can ijust call vortech,or should i just find a dyno and get them to do the whole thing for me?
how freely should the charger spin?i takes a little pressure to get it to spin and i can gear a slight dragging or somthing,its faint but i can still hear it.
Old Aug 31, 2006 | 10:53 AM
ONELOWF's Avatar
My suggestion would be custom tuning with the Xcalibrator2. Have a look through the Chips and tuning forum. With the custom tuning you can use 42# injectors with a 90mm mass air meter. You will likely need to upgrade your fuel pump, not sure about your year. Ditch the FMU if it came with one.
When you turn the s/c by hand, you are spinning the gears which may have a bit of scummy oil on them, and the impellar so there will be a bit of resistance.
I would give Vortech a call for instructions, or visit their web site.
Old Aug 31, 2006 | 11:10 AM
i found the install manual on line,printed it off.
i found the 39# injectors for $130
just need the programmer now or dyno tune
will i need a fuel pump?
Old Aug 31, 2006 | 11:13 AM
madferraristi's Avatar
Your 2005 can't use the regular 42# injectors unless you buy adapter pigtails that switch the plug style, that's why it calls for the 39# Cobra Injectors.
Old Aug 31, 2006 | 11:17 AM
yeah,im going to just get the cobra ones,im not looking to race this thing,just add some umff to it,so the 39# ones will work.$130 i cant beat that.
Old Aug 31, 2006 | 04:43 PM
FATHERFORD's Avatar
1500 is a damn good deal if everything is there.
Old Aug 31, 2006 | 04:51 PM
as far as i can tell,everything is here minus the injectors and the programmer
just got a quote to do the dyno tune for $350.
came with a bag of nuts and bolts,all the major peices are here for sure.i printed the manual and parts sheet off,so we will see.
found a set of 03 cobra injectors for $130,freshly cleaned.so for under $2k i should be good.still need to get a pod and boost gauge though.
