Opinions on which supercharger to go with???
Old Sep 5, 2006 | 09:52 PM
  #106
justjames80's Avatar
It depends on how you look at it. The intercooler does not affect the efficiency of the compressor directly. It does affect the overall efficiency as a system though. It's a compromise situation. You loose boost running any intercooler. But if the intercooler increases the density of the air charge to the point that you still obtain an overall increase in power then it has increased the efficiency overall. On a street driven application an intercooler is always desireable. In race applications it is a different matter. There are Pro 5.0 cars running 30 psi non-intercooled as that's how they've found the most power. They are also running AFR's in the 8's or lower.
Old Sep 5, 2006 | 10:14 PM
  #107
dogedoc's Avatar
One question to the "panel" I sort of suspect I know the answer but I would like to hear it verified. On a new vehicle, I would assume the addition of a s/cer would void the warranty. Am I correct?
Old Sep 5, 2006 | 10:19 PM
  #108
anaheim_drew's Avatar
No, products don't void warranties.. People do if they are allowed
Old Sep 6, 2006 | 06:25 AM
  #109
phil6608's Avatar
[QUOTE=justjames80] You loose boost running any intercooler.
Wow,,I never herd that one before!
Phil
Old Sep 6, 2006 | 06:51 AM
  #110
dogedoc's Avatar
I do not understand this comment. Please explain
Old Sep 6, 2006 | 07:05 AM
  #111
The law says that the dealer must prove that a product caused direct damage to another product thus voiding that items warranty.
Innocent until proven guilty..........Only in a dream
The reality is that you have to prove the product did not cause the failure of the item in question.
Guilty until proven innocent............The real world.
If your brakes fail, trans goes out, the dealer cant just pop the hood and say... supercharger.... that caused the problem... Warranty voided...since they actually dont know untill a tear down of problem area..
Old Sep 6, 2006 | 09:10 AM
  #112
brahmus's Avatar
Originally Posted by justjames80
Anyone here running 14 - 15 psi with a Whipple or Eaton M112 on a factory longblock?
I doubt any with a roots but more so with the twinscrew.
Old Sep 6, 2006 | 09:17 AM
  #113
brahmus's Avatar
Originally Posted by Jordan not Mike
And let us know when that intrercooled KB comes out. It will be very interesting to see how their site changes, because currently the KB site says intercooling is not needed with their blowers:
http://www.kennebell.net/faq/faq-answers3(2).htm
Just FYI KB is notorious for not updating there page. I do know they are suppose to release several (10-12) new kits are so in the very near future. Now not sure if some are going to be intercooled or not though.
Old Sep 6, 2006 | 09:22 AM
  #114
brahmus's Avatar
Originally Posted by lethal_427
Same question for a roots blower. When passing a vehicle that is going about 60 MPH, will I beable to give it just a little bit of gas and pass the vehicle since the boost is supposed to come on in low RPM situations?
That is one of the first things I noticed after the swap. at 60-70-80 mph (I lived in Houston for a while, rush hour traffic flows at 80-85mph ) I could ease into the throttle and I could feel the pull without having to kick down. Same when towing. Now it's more fun to kickdown and pass but you don't need to IMO, if you are driving sensibly.. haha !
Old Sep 6, 2006 | 10:02 AM
  #115
brahmus's Avatar
Originally Posted by dogedoc
3.) People seem to be geeting the wrong idea. Just because one cools a s/cer install, it does not make it more efficient. The efficiency of a blower is by virtue of it's design, not if it is cooled. The s/cer will generate heat either way. The cooling mechanisms help maintain cooler running engine temps.
No it will not change the efficency of the blower but it will increase the efficency of the "system"! The cooling mechanicsm is centered more around making more power, or efficient power with the charged air. By cooling it you are making it more dense allowing for a better burn, more volume, and more timing.
4.) Power is NOT everything. People seeem to be getting hung up on power alone. What are the benefits to the powerplant? Is it stressing the running gear less? Is it more economical to run?
I understand, but it's easier to compare two differnt blowers by keeping as much of the inputs the same as possible and seeing what the output is.
Old Sep 6, 2006 | 10:07 AM
  #116
brahmus's Avatar
In my blown MG, the blower is on the front in between the rails and is air cooled. I once s/ced an MG TC with and under the bonnet, side mounted and belt driven, eccentric vane s/cer know as the Shorrock which was not cooled. When you nailed the accelerator, you would see the temp gauge start to go North real quick. When you ram a charge that is not cooled, the temps go up rapidly. It is this cooling on an intercooler that helps the overall cooling of the powerplant.
I think what you saw was a result of a lean tune more than the fact that air wasn't hitting the blower directly. I could be wrong but charge temps aren't directly related to engine temps but indirectly through the burn.
Old Sep 6, 2006 | 10:11 AM
  #117
brahmus's Avatar
Some but not all. For example, if you have a Roush certified technician install a Roush supercharger and you don't change it up, you do have keep a warantee but from what I understand it is no longer a Ford warantee but covered by Roush.
And it is true that they must prove that modification is what caused the failure but most of the time they can run legal circles around you and you can't find a way to defend yourself.
Old Sep 6, 2006 | 10:32 AM
  #118
brahmus's Avatar
Phil
It's true with all similar setups. You get a pressure drop across a radiator/intercooler. Pressure is related to temperature. Pv=RT where v and R are constants. In simple when you give up T you are giving up P also.
Old Sep 6, 2006 | 11:50 AM
  #119
Phil
Then you learned something.
Old Sep 6, 2006 | 12:44 PM
  #120
brahmus's Avatar
good info here http://not2fast.wryday.com/turbo/maps/#kkk
