Opinions on which supercharger to go with???
Repectfully, I think there may be a bit of mis-information in this thread. Plenty of folks have Procharged/centrifugal-blown trucks and are quite happy with them. Check the dyno sticky, the power curves show there is no narrow band for power. Look at the dyno graphs.
Prochargers run cooler than cents that tap the pan, this has been proven time and time again.
Boost builds progressively. More than stock just off idle (2000 rpm or so once boost starts), though not where a roots/twin-screw are. But cents build power all the way to redline. I run 10.5 psi and have no issues.
I make 410 lb-ft of peak torque, 380 lb-ft at 2800 rpm. It tows a 7000-lb boat with ease, even uphill.
Granted, I put 4.10s in the rear, on street tires, to optimize things further.
I run consistent 14.5 quarters on a GTech, though I don't think it's quite that fast. (Ran a 14-flat on it once but no way in heck it's that fast) But even if I'm around 15 seconds in the quarter, that's pretty impressive for a 3-ton truck with 130K miles that is near 10 years old.
I bough a Procharger because it was used and cheap
But I wanted one anyways. MY 97 had good low-end power, and nothing past 3000 rpm. I already had traction problems on the boat launch ramps stock...still do
I'm not trying to argue over this topic. But take your same truck and add a Kenne Bell or a Whipple Charger and there is NO COMPARISON TO POWER. The screw type WILL simply walk away and never look back. And here is another reason to buy a Kenne Bell or Whipple Charger, you don't have to change the rear gears to a lower ratio. Torque is what pulls NOT HP. The bottom line is that the Procharger will not make the same amount of Torque throught the entire power band as a Kenne Bell or Whipple Charger. Kenne Bells and Whipple Chargers are what the Lightning owners are switching to. There must be some reason why they are switching.
I respectfully call "shananagins" on RustysFX4.
Im sorry but there is no way a substantial amount of oil made its way up from the low mounted a/a intercooler of an ati.The oil will condense on the i/c and collect at the bottom.An engine would have to blow a ring and run for a while to get oil to blow all the way upto the t/body.
As far as power,I think the best 1/4 times are held by Bullet,Fatherford,Pilot,and myself as far as centris on a non factory s/c vehicle. Phill(pimp of times) is doing good things w/ the positive displacement.DYno numbers need not apply
As far as towing..The better seat of the pants you feel while towing,the worse your drivetrain feels.Remember,most of the guys in this forum dont have a 4r100 tranny.Meaning the nice feeling you get while towing,stresses the tranny even more(despite any shift kit or valve body)..
fwiw
I edit to say those best 1/4 mile times are on stock blocks...
fwiw
Out of the 7 of my customers cars 4 were non IC and there was no oil left in the head unit at all. We set the head unit and IC back to procharger, inturn they sent it back with new IC and the same IC and the old head unit. We cut the old IC at the welds about 3.50"'s from the bottom of the IC and there was about 1.5 table spoons of oil left in the bottom. The cars that were running the ProCharger without the IC had no oil left in the head unit at all. These cars were running 15-20lbs of boost when it happend. As far as the rest of the oil from the head unit, where else did it go, there were NO LEAKS at the time of it happening. The only place it could have gone is into the T-body. As far as stress on the drivetrain, this is the result with any power adder, just simply allow more money to go ahead and do what is called preventive maintance. Go ahead and have the trans built to handle the power no matter what. You have to PAY TO PLAY.
I wont argue your ati experiences,but this is the first Ive heard of it in this site or any of the mustang sites.The only reason I can see an ati expelling most of its oil is due to a faulty or inadequate bypass circuit..It happened to me on a road trip,the vacuum line going to the bypass got severed.But when I got home,none of the oil reached the t/body.
You won't see many post on this site about problems with ATI. Go to
www.corral.net and go to the power adder forum and do a search. Here is one.
http://www.corral.net/forums/showthr...arger+problems
I hope this helps explain the ATI customer service issue. Another thing is when it comes time to replace a seal or maintance. ONLY ATI can do the repair work.
Originally Posted by dogedoc
I only partially agree with Brahmus in that it is not so much CFM but rather volume.
The CFM can also be misleading and here is why. If one takes Boyle's law (PV=nrT), then larger volumes automatically translate into the same result of the equation at lower PSI.
No matter how great the technology, even the super output $500k Formula One engines can not fill the combustion chamber of the NA engine 100%.
1.) Which is the comparitvely superior s/cer based on the most economical running (people want power when needed- towing for example- not all the time they don't need it) ?
2.) Which is the s/cer that has a good balance between PSI and volume of charge and therefore more efficient ( higher CFM translate into a larger unit and more work for the engine)?
3.) Which s/cer runs the coolest, thereby translating work into energy rather than heat (the s/ers out there must belong to one category or another)- adiabatic efficiency?
4.) Which has the fewest moving parts and the simplest and most intelligent design which translates into reliabilty?
Originally Posted by Kool Aid
Talking about which one runs the coolest..........how cool does the water get in these external intercoolers?
Seems to me it would be much easier to plumb them into the existing cooling system, that runs at about 180 degrees. Plus, it includes the antifreeze and no need for a separate water pump.
Does this external cooling system run at a much lower temperature?
Originally Posted by phil6608
Kenne bell has an intercooled kit now?
Thats news to me!
Phil
Thats news to me!
Phil
Originally Posted by adt
Dogedoc touched on an important point about stressing the engine with the S/C's. The reason I decided to go with the Procharger P1-SC centrifugal blower for my towing needs is that the positive displacement blowers put out so much low end torque that I might over stress my stock internals resulting in a blown motor possibly sooner than with the cents. I pull a 9000# boat & trailer combo with my 01 SCAB 4x4, 5.4. I've never had a problem getting the weight moving in first gear but I felt I needed more power in the mid to high range such as the highway. Even though I'm still having some issues with my set-up performance wise, I believe I feel more comfortable with my decision to go with the Procharger cause I don't feel I'm stressing the internals too much, especially since I don't feel the need to drag race anyone with my boat in tow. I've read what others have posted about S/C's for towing and I'm going on record by saying my Procharger has definately improved my towing capabilities greatly so don't discard them completely when researching S/C's. Once I get my fuel pump and 12# pulley installed my performance will increase dramatically. Thanks for listening, have a great day.
Originally Posted by RustysFX4
1. But take your same truck and add a Kenne Bell or a Whipple Charger and there is NO COMPARISON TO POWER. The screw type WILL simply walk away and never look back.
2. And here is another reason to buy a Kenne Bell or Whipple Charger, you don't have to change the rear gears to a lower ratio. Torque is what pulls NOT HP.
3. The bottom line is that the Procharger will not make the same amount of Torque throught the entire power band as a Kenne Bell or Whipple Charger.
4. Kenne Bells and Whipple Chargers are what the Lightning owners are switching to. There must be some reason why they are switching.
2. No one ever said you have to re-gear. But you can...and it may help dependng on the speed ranges you run. Also...HP wins races. Not that these are race trucks.
3. True. But HP is comparable, torque is comparable at anything beyond low rpm.
4. That's because it's an easy swap.
I suggest reading the results what folks are gettting with a particular setup, and not just going bench-racing. There is a ton of data - and real-world data is the key to knowledge - on this site and others that clearly shows there is not one right answer...but there is a right one for you.
All I'm saying is, look at the numbers.
BTW all of these blown trucks have oil blow-by issues. A lot of oil gets into the combustion chambers.
Prochargers hold 6 ounces of oil. My catch-cans catch way more Mobil 1 than this over a period of several thousand miles.
My IC probably has more than 6 ounces of oil sitting in it right now
6 ounces is not a lot. In fact, it's very little. A cup of water is what, 12 ounces?
So I'm not sure how this would blow an engine or cause any damage, even if all 6 ounces got dumped in at once.
I tell you this: if my Procharger puked all 6 ounces at once, by the time it went thru the piping and the IC, not much would even make it to the t-body.
But consider that some people pour tranny fluid right into their intakes, my dad did this back in the day. a half-quart at a time...thinking it will clean deposits (old habits never seem to die). These engines smoked a LOT then the oil burns up and all is well.
I can say with some degree of confidence that one could literally squirt all 6 ounces of oil into their t-body and nothing but smoke would happen.
Look, I own a Procharger but I'm no fanboy. All companies have issues. I'm sure there are owners who have problems with ATI. Likewise, there are a lot of owners on this site, some of us long-term, who have not had problems.
The data, the numbers, the results of others are your best bet for info on putting a power-adder onto your truck.
But really, there isn't a bad choice.
Fact is, there are chioices, make the right choice, based on factual data, for what you want to do.
6 ounces is not a lot. In fact, it's very little. A cup of water is what, 12 ounces?So I'm not sure how this would blow an engine or cause any damage, even if all 6 ounces got dumped in at once.
And again,regardless of what the platform,the only way an ati would purge its oil is if there is some kind of obstruction or problem w/ the bypass circuit.
