Boost Gauge Installation
Old Jun 10, 2006 | 06:15 PM
crash_lucky13's Avatar
ok guys i have a 2002 f150 5.4. getting ready to put my boost gauge in. what vaccuum line do i tie into??
Old Jun 10, 2006 | 07:28 PM
Saff 02 F150's Avatar
There should be a rubber line running behind your battery, check behind and to the right of the battery (I think it's behind the starter solenoid?), there should be a T there with one end capped off. Remove the cap and tie in your line onto that T.
Old Jun 11, 2006 | 12:24 AM
hey you got it man. thanks.
Old Jun 11, 2006 | 01:34 PM
silversvt04's Avatar
Great ... I just bought a boost guage yesterday and was wondering the same.
Thank-x
Old Jun 11, 2006 | 01:55 PM
didn't you lightning come stock with one???
Old Jun 11, 2006 | 04:25 PM
ok i hooked it up to the vaccuum line. but here's a question. why is the gauge reading 19lbs of boost? should be more around 11lbs. ???????
Old Jun 11, 2006 | 08:36 PM
Are you sure it's reading boost and not vacuum? (Don't mean to offend, but I couldn't think of anything else.) Otherwise, there's no way you should be seeing 19lbs of boost, possibly broken gauge?
Old Jun 12, 2006 | 12:34 AM
i don't know too much about boost gauges honestly. it's reading that much on the vacuum side. anyone care to explain to me the difference?
Old Jun 12, 2006 | 01:09 AM
ONELOWF's Avatar
It will run in vacuum until the boost comes on, usually around 3000 rpm with a centri, and max boost at redline. Mine shows vacuum on the left side of the zero, and the boost on the right side of the zero.
Old Jun 12, 2006 | 01:57 AM
Yes it did, but I also bought a pillar pod. and other guages etc...
Old Jun 12, 2006 | 04:37 AM
i just got a pod that fits over the steering column.
gotta try to figure that gauge out tomorrow. think i am just going to tap into my main intake
Old Jun 12, 2006 | 08:28 AM
ONELOWF's Avatar
You can T off of the larger vac line at the pass side rear of the intake elbow. There should be a large and small vac line there coming out of a preformed elbow......tap into the larger one. It sounds like the way you have it now should work though. It may be a matter of less boost showing than you think you should have.
