problem with supercharger i think
well i got my supercharger on and now when i press the gas down hard it like crackles loud through the exhaust and like feels like its slwoing down. i dunno what it is i thought i may of had bad gass int eh truck but i dont know now. it like jerks when u get on it please help
do you have 91 in the tank? also check for vacuum leaks.
http://media.putfile.com/smoken-f-150
yea i have 91 in the tank and i can check for vacuum leaks but the other thing iwas wondering if it was getting to much fuel. i am using the boost a pump because i have a kenne bell supercharger and i havent quite figured out exactly where the dial should be ne one else have ideas
jjxtrf150,
Talk to whom ever installed you kit. They should know the setting on the boost a pump. Otherwise, I would call Kenne Bell and ask to talk to a technician. They will be able to set you up quick. Good luck, and lets hope its not detonation.
In my case he just pulled back the timing a bit.
How much boost are you running? Stock injectors? Stock fuel pump?
Blowers are never just straight bolt ons. They take some tuning and massaging to get them right. You'll get it where it needs to be. Go easy on it until its fixed incase it is detonation or a lean condition.
GOOD LUCK! Im willing to bet its a fuel and timing issue.
