lightning swap help
Old Jul 11, 2005 | 12:28 PM
  #121
iron horse's Avatar
Great thread! Play by play threads are great reads.
On this website, I have seen many problems caused by a person trying to lay the entire assembly down on the gaskets/heads, by themselves.......especially, if they had just downed some
If you can stand upright, in the engine bay, you can lay the entire assembly down on the gaskets by yourself, without the possiblity of damaging the gaskets, but its better to ask someone for 5 minutes of their help to save a lot of grief .
Did it start-up?
Old Jul 11, 2005 | 01:16 PM
  #122
adami67's Avatar
Each time that it has leaked, was the leak in the same place?
Old Jul 11, 2005 | 11:58 PM
  #123
jonjon62288's Avatar
yes it leaked at the same place. and negative did not start!!
everything you can think of i bought new all except a new engine.
when i turn key, i get click again. so i tried jump it at the relay, click.
my battery is charged at 13.1 volts. i even tried my other car's battery. same result.
my relay is new, starter is new, battery new, battery cable new.changed all the nuts and bolts for the new starter. cleaned my ground area. took off my remote start alarm.
what should i do? well, need to take a break tommoro, wednesday is my board exam. ..
Old Jul 12, 2005 | 09:38 AM
  #124
raider's Avatar
can you turn the engine over by hand? put a breaker bar on the crank pulley and try to turn over motor first
Old Jul 12, 2005 | 11:43 AM
  #125
do i do this with the belt on or off? ( turning the engine by hand)
Old Jul 12, 2005 | 11:59 AM
  #126
brahmus's Avatar
do it with the belts off first and spin everything over!
Old Jul 12, 2005 | 09:04 PM
  #127
sorry, but which way do i turn? ( clock wise and counter?) it seems stuck, maybe i didn't turn it right. how do i manualy turn my crank?
and is there a reason why my battery keeps draining eventhough nothing is on.
thank you all.
Old Jul 12, 2005 | 09:08 PM
  #128
CoMikeF150's Avatar
Wow! What a story... man I feel your pain. To turn the engine over, take the spark plugs out, take the belt off and try to spin the crank pulley. The crank should rotate either direction I would imagine. I wonder if your engine is seized. One thing, if you have some time... remove the starter from the engine and then turn the ignition key and see if the starter spins. (Be careful.)
Good luck!
Old Jul 13, 2005 | 01:06 AM
  #129
thanks comike150, so with the spark plug out and belt off, i should be able to spin the crank with my bare hands like the other pulley? and what if my engine is seized? ( what signs)? i did had radiator coolant in my engine due to cracked gasket.
Old Jul 13, 2005 | 02:35 AM
  #130
madferraristi's Avatar
If you can turn it with your bare hands, I don't want to shake hands with you. However, it should turn easily with a 1/2" ratchet.
Before you turn it, roll up eight sheets of paper towel and put one down to the bottom of each spark plug hole. After you turn it two complete revolutions, pull the paper towels out. If any one of them is wet then you most likely had a hydraulic lock in that cylinder from your coolant leak.
Now turn the key and see if the starter will spin the engine.
Old Jul 13, 2005 | 02:51 AM
  #131
pretty funny mike,
ok, take off the spark plugs ( agian) i should of bought the coil pack screw from madenterprise.. i'll do that tommoro afternoon after my exam. thanks again mike.
Old Jul 13, 2005 | 09:27 AM
  #132
No humor intended, I am at a complete loss as to what is causing your problem.
Old Jul 13, 2005 | 09:35 AM
  #133
brahmus's Avatar
I think you need to step back and start from the beginning. i too think something is binding up. hydrolock maybe... just slow down and check everything over and over. you are missing something simple.. get a check list going..
forget the battery for now you can always jump it. get the motor turning with a breakerbar first. try with no coolant in it, see if she'll crank for a sec then shut it down.. break this problem down piece by piece.
Old Jul 13, 2005 | 11:03 AM
  #134
ok, done take out the spark plugs, need to take shower and go take exam.
one question, where to stick the break bar into? what part of crank pulley? and i've check all 8 spark plug chambers, all with no sign of water/coolant. the spark plugs are dry and clean.
Old Jul 13, 2005 | 11:16 AM
  #135
There is a large bolt in the middle of the Crankshaft Damper, put a socket on it, short extension and a rachet. Don't forget tha paper towels, we're only talking about 50cc's of coolant here needed to hydraulic lock the engine.
