Factory Lightning SC compatible with 97 5.4L?
Old Nov 2, 2003 | 04:15 PM
ZO6Cam's Avatar
Thanks for all the replies. Based on what I've seen here, it looks like I would be better off with an aftermarket kit.
FWIW, my Expedition is equipped with the E4OD transmission according to my manual. "E4OD transmissions are used with 5.4L engine applications." Its also a 4X4. The drivetrain setup looks like its extremely stout.
Old Nov 2, 2003 | 04:54 PM
sirket's Avatar
The E40D is the 4R100 (same family). It is an extremely strong transmission but it still might not be enough for the Lightning engine. The Lightning uses a special version of the 4R100. As Gregg Evans likes to say, the Lightning 4R100 is the strongest gasoline transmission available.
-Don
Old Nov 2, 2003 | 08:05 PM
ZO6Cam's Avatar
-Don
Cool deal. I didn't know that. I'm still learning about Fords! Thanks for the info!
Old Nov 3, 2003 | 10:47 AM
iron horse's Avatar
Originally posted by madferraristi
OK, I have done it but I did it the "right" way. Swapped the engine, trans, PCM, wiring harnesses, and added all of the necessary accessories to essentially make mine a Supercab Lightning, with some fairly healthy mods to boot.
Hey Mad.! How is it running? Can you provide a comparison between the lightning set-up and your former ATI set-up?
I still need your help with my fuel mods.
Old Nov 3, 2003 | 10:57 AM
madferraristi's Avatar
Well, so far, without mods I love it. While the all out power is not yet up to the level (note "not yet") of my ATI setup, the low rpm driveability is superior.
I should have it modified and on the Dyno before the end of the month.
Old Nov 4, 2003 | 12:22 AM
iron horse's Avatar
.....after seeing the results of the improvements you made to the ATI system, I can hardly wait to see the combo of mods, that you come up with for the lightning set-up, for max. results.......since I am going to want those mods as well!!!!!!!!!!
Old Nov 7, 2003 | 10:31 AM
iron horse's Avatar
Originally posted by Crash!
I have worked fairly closely on two of these projects. Originally, it was believed ALL Lightning parts needed to be swapped. Now we know you can bolt it up, run it, then let Dom tune it. Just upgrade the rest as it breaks.
Derek
.........what the !?! You have helped with two (2) lightning swap projects already!?!?!?! Share your expertise Power Broker.....there are more than several of us with lightning parts that are dazed and confused!
Yeah, I figure that the very custom tuning that Dom can provide should max. the potiential of a lightning swap.
Old Nov 7, 2003 | 09:42 PM
ZO6Cam's Avatar
Crash!, so tell us more. Please.
Old Nov 10, 2003 | 01:12 AM
banksbigred16's Avatar
madferrari,
thanks for the info man it is well appreciated and has been a good learning experience.
thanks again
banks
Old Nov 10, 2003 | 02:33 AM
Anybody who has an OE supercharger setup that they intend to install their truck might benefit from the list of parts I have compiled that are necessary.
Send me an e-mail or a PM and I'll share the information with you.
