ATI Removed....HELP....Problem....
Old Oct 2, 2003 | 12:42 PM
KeithG's Avatar
Hello
I had my ATI removed from my truck, 42 lb injectors, 90 mm MAF, ATI Fuel Pump, Chip.............and all stock parts put back on.
When the truck is started it runs VERY rough....kind of like a bad cylinder (which it doesn't have because it drove fine a minutes before the kit was removed).
Does anyone have any idea what may cause this? Bad stock injector? PCM issue....does it need to be re-programmed? Any ideas? Argh
Old Oct 2, 2003 | 01:31 PM
offroadmaniac's Avatar
Did you take the chip out that was tuned for the 42lb injectors?
Is there any gas leaking?
Spark plugs fine?
Old Oct 2, 2003 | 01:49 PM
KeithG's Avatar
The chip is out. Once the chip is removed, does anything need to be done?
No gas leaking and plugs seem ok.
Damn...this sucks. What else could do this? Runs like crap.
Old Oct 2, 2003 | 03:20 PM
outdare's Avatar
KeithG,
Maybe you have a bad coil? Did anything get banged around when you removed the ATI? Have you reset the PCU? Check the fuses and connections. (like the camshaft sensor on the front where the ATI braket was, Vaccum leaks can of starter fluid, the MAF etc..) Are you throwing any codes?
Bill
Old Oct 2, 2003 | 07:06 PM
KeithG's Avatar
Thank you for replying..............I think we figured it out. One of the injectors in the back (by the firewall) was not seated correctly. Removed it and reinstalled it and the truck is running normally.
Old Oct 2, 2003 | 08:38 PM
I figured there would of been some gas leakage.
Old Oct 2, 2003 | 08:52 PM
KeithG's Avatar
I thought so too, but it must have been off just enough to not get the proper amount of fuel to the cylinder.
Old Oct 2, 2003 | 08:59 PM
Yea, I figured it sounded like an injector. I left one of my o-rings off an injector one time, and it wouldn't even idle. But, fuel sprayed everywhere. It covered my garage floor and the whole engine bay.
