BBK 75mm T/B
Old Jun 23, 2003 | 12:39 PM
01screw's Avatar
BBK 75mm T/B
Are these throttle bodies any good? Did you notice any difference? Worth the money? Thanks!!!
Old Jun 23, 2003 | 02:30 PM
outdare's Avatar
01screw,
I have one on my truck. I have a ATI so I see a better throttle response. For the 2 hundred or so bucks I wouldn't suggest it. The $ to 12 hp ratio is really bad. I would suggest fans, chip, hiflow cats are about the same price.
Old Jun 23, 2003 | 10:11 PM
RayCee's Avatar
If you are considering the throttle body just remember that you have to port the elbow to match. Otherwise it wont do a thing for you.
Old Jun 24, 2003 | 12:40 PM
01screw's Avatar
Thanks guys. From what I'm reading on different sites, it don't seem like a worthwhile mod.
Old Jun 25, 2003 | 06:47 PM
Blown2run's Avatar
I HAVE ONE TOO. SHOULD'VE SPENT THE MONEY ON OTHER MODS.
Old Jun 26, 2003 | 07:44 AM
BROTHERDAVE's Avatar
25 Year Member
in a mustang mag i have they tested airflow on a 4.6 sohc mustang and the addition of the tb was around 20 cfm. they then had the elbow professionaly ported and picked up a little over 50 cfm with the stock tb and made 10 hp pretty much accross the board. the place that did it charged $156 (and a $55, refundable exchange) if it picked up 10 hp (dyno jet so thats rearwheel) then thats $156 well spent. you would have to think the gains would be bigger with a s/c.
Old Jun 26, 2003 | 03:08 PM
outdare's Avatar
BrotherDave,
I guess there not including the price of the TB. I think the BBK is like 250 plus the 156 bones. If he just polished the intake and gained 10 hp then that is a good deal.
Old Jun 26, 2003 | 10:37 PM
25 Year Member
gain was with the stock throttle body. you could do this at home in the garage but i doubt the results would be the same.
also the elbow was flow tested.
Old Jun 28, 2003 | 06:41 PM
outdare's Avatar
Brotherdave,
Check out the new Hot-rod mag. It has a bunch of mustang info as well as a boost comparison on roots, centitrifigal and turbos.
Old Jul 6, 2003 | 08:25 PM
25 Year Member
outdare, that a good article, makes you wonder why there is not a turbo kit available for the f150, the centrifigal -roots thing could be argued , but the turbo is the clear winner.
