Remove FMU after 42lb injectors and MAF
Old Apr 24, 2003 | 03:22 PM
MHZMAN's Avatar
Just wanted to get some carification on this, my truck is getting the fuel upgrades to 42pd injectors and the 90MAF, it is okay or advised to remove the ATI FMU at this time, am I correct. I am leaving the boostapump for now until I can upgrade to the larger in tank fuel pump.
Old Apr 24, 2003 | 09:05 PM
mthunwardsen's Avatar
True, just remember you need a tune to run the 42# injectors, and the 90 mm MAF. Trust me, it is a whole new world, 9 psi stock vs. 12 psi and fuel mods. I will never go back.
Old Apr 25, 2003 | 01:15 AM
1JT's Avatar
1JT
mthunwardsen
So are you still CA smog legal w/ these mods?
Old Apr 25, 2003 | 09:56 AM
MHZMAN's Avatar
mthunwardsen, I am just doing the injectors and MAF with the custom tune for now. I may upgrade the pulley later. Is this okay also.
Old Apr 28, 2003 | 04:18 PM
MHZMAN's Avatar
Thanks Crash, the truck is going to LaRocca's for the Dyno and custom tune on the chip.
Old Apr 28, 2003 | 04:28 PM
As far as being smog legal, I should not have any problem, assuming I pass the sniffer. I had Dom make my other program be emissions/economy. So I should probably run a little leaner on that one. As far as visual, I have not changed any of the smog equipment. I don't have a vented crank case, I still have my cats, etc, my chip is programmed to run the 42# injectors, so a idle and low rpms, I should be just fine.
Old Apr 28, 2003 | 09:23 PM
LScab's Avatar
Better paint the tops of those injectors!
Old Apr 29, 2003 | 07:24 PM
The chances of someone knowing the difference are slim to none. Anyways, just hang onto your old ones, I have had to convert my truck back to stock more than once. I can get it there in just about 2 hours now. But it goes back to being a gut-less turd them.
Old May 9, 2003 | 06:56 PM
Big Orange's Avatar
Registered User
I just installed a Magna charger on my 97 5.4 and I am now saving up for the injector and MAF upgrade myself. I was wandering if it is possible to do a custom tune on the stock setup with the FMU or if you have to upgrade the injectors and MAF before be able to tune the PCM? I was thinking of getting a custom tune now and having the chip reburned when I upgrade the injectors and MAF.
