08 4wd screw goin low
So I'm lookin into this whole lowering the 4wd. I had an 04 with the 3.5/5 djm controll arms and flip kit. Although it was bad ***. it was lower than I want to go this time. I'm thinking that with the 4wd being naturally higher if I do the 3" arms and flip in the rear it will be exactly what I'm after. I dont want to have to worry about rubbing the fender liners or hitting the rear bumpstops.
Anyone done this and have pictures or suggestions? I plan to run the stock 18s in the winter and a 275 55 20 in the summer
so now that ive done more looking into this, someone correct me if im wrong. i can remove my rear block and use 2" lowering shackles to get 4" in the rear. in the front i can replace my struts with a 2wd set and get 2 inches lower. or get 2" lowering coils.
the truck has 90k miles so i would most likely go with struts if that works.
