Djm 3/5 drop with 24's any suggestions?
Old Dec 1, 2011 | 12:34 PM
T_S_S's Avatar
Former Sponsor
Be careful with the control arms. I would recommend the Belltech Lowering Strut and Belltech Spindles.
Old Dec 1, 2011 | 12:56 PM
jsvo5695's Avatar
Control arms and spindles is what I am running in conjunction with drop struts. And it puts me right at 5.5" in the front. But to go that low you need the mod the tie rod ends and notch the heck out of the cross member. And get ready to rub!!!
Old Dec 1, 2011 | 01:00 PM
azmidget91's Avatar
2.5" Control arms and 2" spindles here, cut tie rods and no crossmember notching here. and minimal to no rubbing
Old Dec 1, 2011 | 01:02 PM
jose_bigred's Avatar
Yeah so i hear if i want to combine lowering components its best to use spindles and CA's. I will no longer be using 24"s so i will go pretty low this time around and find some OEM 20's.
How much did you spend on notching the frame?
Old Dec 1, 2011 | 01:05 PM
Sounds like a good static drop to me.... but i really dont feel like dishing out the wallet for the spindles lol
Old Dec 1, 2011 | 02:11 PM
Milt IV's Avatar
You gotta pay to play. Nothing about lowering a truck is cheap. I have learned that it is best to spend the money when it matters. I have learned this through trying pretty much every different drop setup you can think of on several different trucks. You don't want to half a$$ it and be unsatisfied with your finished product. Take your time, buy the best products, and don't cut any corners.
Old Dec 1, 2011 | 02:57 PM
I hear you there. This will be my second set up so i know what yor saying.
Probably just gonna run my 3.5" CA's and flip kit for now. Then later get the spindles for a lower set up.
Old Dec 1, 2011 | 03:54 PM
azmidget91's Avatar
I spent $6 on my notch
Old Dec 1, 2011 | 04:39 PM
^ With alot of elbow grease!!!lol Good stuff tho
Old Dec 1, 2011 | 05:10 PM
azmidget91's Avatar
More like a torch and a welder hahaha and about 4 hours of stressing out about cutting my frame
