DJM...BellTech...or ??
Old Jun 3, 2010 | 12:10 AM
COCIMitch's Avatar
I am wanting to drop my 06 FX4 using a 2/4 kit but not sure which one to use. Any suggestions which is the better way to go?
Old Jun 3, 2010 | 12:21 AM
heckvr4's Avatar
not sure wich one its better 'but'......
i have a djm 3/5 drop kit for sale if you are interested..... its a flip kit on the rear and lower control arms for the front...
lol... good luck mang/...
Old Jun 3, 2010 | 09:51 AM
07ScrewF150's Avatar
I'm really liking the Belltech drop struts on the front of mine, you can do stock height, -1", -2" or -3" just by changing the rings below the spring perch and they ride great.
Mine is lowered 4" because I have 3" coils and set the struts to lower it some more so mine does bottom out on big bumps but with only 2" I doubt you would have this problem.
So far as the back I have the djm flip kit but that is gonna be lower than you want so I can't comment on what to do back there.
Old Jun 6, 2010 | 02:23 PM
mmalcolm24's Avatar
I usually use the belltech struts up front because they are good for up to 3" drop and for the rear I would use a belltech flip kit they are way nicer then the DJM kits or you can also use Eibach spring in the rear
Old Jun 6, 2010 | 05:28 PM
COCIMitch's Avatar
I bought a DJM 3/5 kit from boardmember heckvr4. Found several articles on them and they look OK. Will post pictures when it arrives and it's installed. I have used Eibach Proline lowering springs on my 95TA conv. Those were excellent!!
Old Jun 6, 2010 | 09:01 PM
You'll retain stock ride with the DJM kit.
Personally I have a Ground Force 2/4 drop, coils and leafs. I am also running the Eibach pro damper kit, which is coilovers/shocks.
These work well together. I have a very sporty ride that is not harsh at all. Just how I like it.
Old Jun 6, 2010 | 09:14 PM
jsvo5695's Avatar
the lower the better!
