how much should i lower my truck?
Old Nov 3, 2009 | 11:11 PM
blaineb22's Avatar
nice truck mixedbreed. i like the white, wish i could find a white one.
Old Nov 3, 2009 | 11:16 PM
bankrpt's Avatar
Yeah it settles rides like a charm when I had my
22s with 35 series sidewall rode better than stock but with the 24s still rides just as good just feel more cause of the 30 series tires if u do the djm kit u will want 22s with 35 series sidewalls I had both 35 and 40 the 40 would rub if u do djm on 24s u will have to run 30s cause I tried 35s and rubbed like crazy
Old Nov 4, 2009 | 12:41 AM
blaineb22's Avatar
do you have any pictures of it with the 22s? The only thing im worried about is the kit wont drop mine as low as your truck because the crew cab weighs alot more than a reg cab and theres only one kit for crew cab/ext cab/reg cab and not a seperate one for each like the silverado drop kits.
Old Nov 4, 2009 | 08:55 AM
bankrpt's Avatar
Ill have to see if I got a pic get the djm kit then get the belltech street performance front and back shocks and u can also lower the front shock from 0-3" and then u could get ur other half inch if need be that's the shocks I have but mine are set a 0 drop
Old Nov 4, 2009 | 05:53 PM
blaineb22's Avatar
that sounds like a good idea. Does anyone know which kit drops the f150s lower the belltech 4/5 or the djm 3.5/5? and does anyone know whats the lowest i can go and not have a problem with alignment?
Old Nov 4, 2009 | 06:37 PM
bankrpt's Avatar
4 is about the lowest I would go mine is just tipping the mark where it can't be aligned I think the belltech is 3-5 u might be able to go down to 4.5 in the front but I would push it no further
Old Nov 4, 2009 | 07:09 PM
I'm on a GF 2/4 drop with eibach dampers and 305/40-22's.
Old Nov 4, 2009 | 08:16 PM
87fiveoh254's Avatar
When did you get the hood on, Stealth? Looks sick!
Old Nov 4, 2009 | 08:58 PM
I've had it for a looooooong time, still need to get it painted, it's just primed black. :o
Old Nov 4, 2009 | 10:16 PM
Well it's a good 20 footer for now.
Old Nov 4, 2009 | 10:24 PM
azmidget91's Avatar
I would probably go for the 3.5/5
x2222222222222222222222222222222
Old Nov 4, 2009 | 10:48 PM
bankrpt's Avatar
i just got done looking the bell tech is just 3-5 drop the djm is 3.5-5 id go with the djm kit if i was you
this is the drop kit http://www.stylintrucks.com/part.asp...&partid=559722
rear shocks http://www.stylintrucks.com/part.asp...&partid=601964
front shocks http://www.stylintrucks.com/part.asp...&partid=525647
Old Nov 4, 2009 | 11:57 PM
blaineb22's Avatar
thanks for the help bankrpt and everyone else!
Old Nov 5, 2009 | 12:02 AM
anaheim_drew's Avatar
Originally Posted by blaineb22
I am looking for opinions on how much should i drop this truck on some 22" rims with around a 275/45/22 tire.
I would like my truck to have as little gap as possible between the fender and the tire, but not so much that it rubs without even hiting a pot-hole.
275/45/22 will rub with a 3.5 front drop
Old Nov 6, 2009 | 12:32 AM
blaineb22's Avatar
really? what size tire do you suggest?
